<!– Class –> Represents an overlay object that gets map images from the WMS server you specify.
The <strong>WmsOverlay</strong> gets images from one or more WMS servers that you specify. Usually, you add a WMS server URI to the <strong>ServerUris</strong> collection and the <strong>WmsOverlay</strong> will make a request to that WMS server to get its tile images.You can also add multiple WMS server URIs to the ServerUris collection. The WmsOverlay will randomly send requests to those WMS servers in a concurrent fashion. This means that the tile images can come from different WMS servers, thus greatly enhancing performance. <strong>Do not</strong> add URIs of differently-configured WMS servers to the ServerUris collection.
WmsOverlay | Initialize an instance of the WmsOverlay class. | ||
WmsOverlay | String | Initialize an instance of the WmsOverlay class with the overlay identifier specified. | |
WmsOverlay | String, Uri | Initialize an instance of the WmsOverlay class with the overlay identifier and a WMS server URI specified. | |
WmsOverlay | String, Uri, TileType | Initialize an instance of the WmsOverlay class with the overlay identifier, the WMS server URI and the tile type specified. | |
WmsOverlay | String, IEnumerable<Uri>, TileType | Initialize an instance of the WmsOverlay class with the overlay identifier, the collection of WMS server URIs and the tile type specified. |
GetBaseEpsgProjection | Returns an EPSG string that indicates the projection of the LayerOverlay. | ||
SetBaseEpsgProjection | String | Sets the EPSG projection of the LayerOverlay when it is a base overlay. | |
ToJson | Overlay | Returns a JSON string which contains the information for creating an overlay at the client side. | |
MemberwiseClone | Object | ||
OnTick | EventArgs | Overlay | Raises the Tick event of the MarkerOverlay. |
RegisterJavaScriptLibraryCore | Page | Overlay | Registers a Javascript library URL string to the client HTML page. |
Attribution | String | Overlay | |
AutoRefreshInterval | TimeSpan | Overlay | Gets or sets the time interval in which the MarkerOverlay refreshes itself. |
Id | String | Overlay | Gets the identifier for the overlay to be found. |
IsBaseOverlay | Boolean | Overlay | Gets or sets a value that indicates whether the overlay is a base overlay. |
IsVisible | Boolean | Overlay | Gets or sets a value that indicates whether the overlay is visible on the map. |
IsVisibleInOverlaySwitcher | Boolean | Overlay | Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher. |
Name | String | Overlay | Gets or sets the name of the overlay, which will display in the OverlaySwitcher. |
Opacity | Single | Overlay | Gets or sets the opacity level of the overlay. |
Parameters | Dictionary<String,String> | Gets a dictionary whose items will be passed to the WMS server as parameters. | |
ServerUris | Collection<Uri> | Gets a collection of URIs that specifies the locations of the WMS servers. | |
TileHeight | Int32 | Gets or sets the height of each tile, if the WmsOverlay uses tiling. | |
TileType | TileType | Gets or sets whether or not the WmsOverlay uses tiling. | |
TileWidth | Int32 | Gets or sets the width of each tile, if the WmsOverlay uses tiling. | |
TransitionEffect | TransitionEffect | Gets or sets the transition effect to use when the map is zoomed. | |
TransitionEffectDelayInMilliseconds | Int32 | ||
WebImageFormat | WebImageFormat | Gets or sets the format of the image that is sent to the web browser. | |
WrapDateline | WrapDatelineMode | Gets or sets a value that indicates whether the overlay wraps at the date line. |
HasTickEvent | Boolean | Overlay | Indicates whether the overlay supports tick event. |
OverlayType | String | Overlay(overriden) | Gets a string that indicates the overlay type. |
Projection | String | Gets or sets a string that will be sent to the WMS server to get the images in the specific projection. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#WmsOverlay.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#WmsOverlay.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#WmsOverlay.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#WmsOverlay.28String.29</a>
| id | String<!– System.String –> | The identifier string used to find the overlay. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#WmsOverlay.28String.2C_Uri.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#WmsOverlay.28String.2C_Uri.29</a>
| id | String<!– System.String –> | The identifier used for finding the overlay. |
| serverUri | Uri<!– System.Uri –> | The URI that indicates where the WMS server is. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#WmsOverlay.28String.2C_Uri.2C_TileType.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#WmsOverlay.28String.2C_Uri.2C_TileType.29</a>
| tileType | TileType<!– ThinkGeo.MapSuite.WebEdition.TileType –> | Whether or not the overlay uses tiling. |
| serverUris | IEnumerable<Uri><!– System.Collections.Generic.IEnumerable{System.Uri} –> | The collection of WMS server URIs. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#GetBaseEpsgProjection.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#GetBaseEpsgProjection.28.29</a>
| String<!– System.String –> | An EPSG string that indicates the projection of the LayerOverlay. |
<!– ThinkGeo.MapSuite.WebEdition.WmsOverlay –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#SetBaseEpsgProjection.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#SetBaseEpsgProjection.28String.29</a>
| epsgProjection | String<!– System.String –> | A string that represents the projection of the LayerOverlay. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#ToJson.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#ToJson.28.29</a>
| String<!– System.String –> | A JSON string which is used to create an overlay at the client side. |
<!– ThinkGeo.MapSuite.WebEdition.Overlay –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#OnTick.28EventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#OnTick.28EventArgs.29</a>
| e | EventArgs<!– System.EventArgs –> | An System.EventArgs object that contains the event data. |
The <strong>RegisterJavaScriptLibraryCore</strong> method allows derived classes to override and register their own Javascript library URL to the HTML page.
| page | Page<!– System.Web.UI.Page –> | The page object that is used for registering the javascript library. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#Attribution” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#Attribution</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#AutoRefreshInterval” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#AutoRefreshInterval</a>
| TimeSpan<!– System.TimeSpan –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#Id” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#Id</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#IsBaseOverlay” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#IsBaseOverlay</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#IsVisible” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#IsVisible</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#IsVisibleInOverlaySwitcher” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#IsVisibleInOverlaySwitcher</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#Name” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#Name</a>
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#Parameters” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#Parameters</a>
| Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#ServerUris” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#ServerUris</a>
| Collection<Uri><!– System.Collections.ObjectModel.Collection{System.Uri} –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#TileHeight” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#TileHeight</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#TileWidth” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#TileWidth</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#TransitionEffect” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#TransitionEffect</a>
| TransitionEffect<!– ThinkGeo.MapSuite.WebEdition.TransitionEffect –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#WebImageFormat” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#WebImageFormat</a>
| WebImageFormat<!– ThinkGeo.MapSuite.WebEdition.WebImageFormat –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#WrapDateline” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#WrapDateline</a>
| WrapDatelineMode<!– ThinkGeo.MapSuite.WebEdition.WrapDatelineMode –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#HasTickEvent” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#HasTickEvent</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#OverlayType” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WmsOverlay#OverlayType</a>
<!– ThinkGeo.MapSuite.WebEdition.Overlay(overriden) –> Go Back
Occurs when the number of milliseconds specified in the AutoRefreshInterval property has elapsed and the page is posted to the server.
| Event Arguments |
NOTOC WebEdition ThinkGeo.MapSuite.WebEdition UpdateDocumentation
