thinkgeo.mapsuite.webedition.panzoombarmaptool
ThinkGeo.MapSuite.WebEdition.PanZoomBarMapTool
<!– Class –> Represents the panning and zooming panel in the upper left corner of the map.
The PanZoomBar map tool consists of a panning control, two zooming buttons and a zoomlevel bar. The panning controls have four panning buttons and a globe button that zooms the map out to show the whole world. The zoomlevel bar represents the zoomlevels of the map (20 zoomlevels altogether). There is a slider on the zoomlevel bar that indicates the map's current zoomlevel. By moving the slider, you can change the map to a different zoomlevel. This map tool is enabled by default.
Public MethodPanZoomBarMapTool Initialize an instance of the PanZoomBarMapTool class.
Public MethodGetType Object
Public MethodToJson MapTool Returns a JSON string that represents the map control object.
Public MethodToString Object
Public PropertyEnabled Boolean MapTool Gets or sets a value that turns the feature on and off.
Public PropertyIsGlobeButtonEnabled Boolean Gets or sets a boolean value that determines whether the globe button shows in the PanZoomBar map tool.
PanZoomBarMapTool()
Name Type Description
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
ToJson()
This method returns a JSON string that instructs the client Javascript to create a specific client object.
String<!– System.String –> A JSON string that represents the map control.
<!– ThinkGeo.MapSuite.WebEdition.MapTool –> Go Back
Void<!– System.Void –>
Enabled
Return Type
Return Type
<!– ThinkGeo.MapSuite.WebEdition.PanZoomBarMapTool –> Go Back
thinkgeo.mapsuite.webedition.panzoombarmaptool.1440040135.txt.gz · Last modified: 2015/09/18 03:09 (external edit)
