thinkgeo.mapsuite.webedition.minimapmaptool
ThinkGeo.MapSuite.WebEdition.MiniMapMapTool
Represents a mini map panel in the lower right corner of the map.
    • ThinkGeo.MapSuite.WebEdition.MapTool
      • ThinkGeo.MapSuite.WebEdition.MiniMapMapTool
MiniMapMapTool()
  • Initialize an instance of the MiniMapMapTool class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#MiniMapMapTool.28.29
ToJson()
  • Returns a JSON string that represents the map control object.
  • This method returns a JSON string that instructs the client Javascript to create a specific client object.
  • Description:A JSON string that represents the map control.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#MemberwiseClone.28.29
MaximizeRatio
The ratio of the mini map resolution to the main map resolution at which to zoom farther out on the mini map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#MaximizeRatio
MinimizeRatio
The ratio of the mini map resolution to the main map resolution at which to zoom farther in on the mini map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#MinimizeRatio
Enabled
Gets or sets a value that turns the feature on and off.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#Enabled
thinkgeo.mapsuite.webedition.minimapmaptool.1442911779.txt.gz · Last modified: 2015/09/22 08:49 by admin
