thinkgeo.mapsuite.webedition.minimapmaptool
ThinkGeo.MapSuite.WebEdition.MiniMapMapTool
Represents a mini map panel in the lower right corner of the map.
    • ThinkGeo.MapSuite.WebEdition.MapTool
      • ThinkGeo.MapSuite.WebEdition.MiniMapMapTool
MiniMapMapTool()
Initialize an instance of the MiniMapMapTool class.
ToJson()
MaximizeRatio
The ratio of the mini map resolution to the main map resolution at which to zoom farther out on the mini map.
MinimizeRatio
The ratio of the mini map resolution to the main map resolution at which to zoom farther in on the mini map.
Enabled
thinkgeo.mapsuite.webedition.minimapmaptool.1442545729.txt.gz · Last modified: 2015/09/18 03:08 by admin
