<!– Class –> Represents a mini map panel in the lower right corner of the map.
The mini map panel is located in the lower right corner of the map and can be expanded or collapsed. It maintains an entire overview of the map even when you have deeply zoomed in. Set the <strong>Enabled</strong> property to true to display it on the map.
MiniMapMapTool | Initialize an instance of the MiniMapMapTool class. |
Enabled | Boolean | MapTool | Gets or sets a value that turns the feature on and off. |
MaximizeRatio | Int32 | The ratio of the mini map resolution to the main map resolution at which to zoom farther out on the mini map. | |
MinimizeRatio | Int32 | The ratio of the mini map resolution to the main map resolution at which to zoom farther in on the mini map. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#MiniMapMapTool.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#MiniMapMapTool.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#GetType.28.29</a>
Returns a JSON string that represents the map control object.
This method returns a JSON string that instructs the client Javascript to create a specific client object.
| String<!– System.String –> | A JSON string that represents the map control. |
<!– ThinkGeo.MapSuite.WebEdition.MapTool –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#Enabled” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#Enabled</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#MaximizeRatio” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#MaximizeRatio</a>
<!– ThinkGeo.MapSuite.WebEdition.MiniMapMapTool –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#MinimizeRatio” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#MinimizeRatio</a>
