thinkgeo.mapsuite.webedition.minimapmaptool [2015/08/20 03:08] 127.0.0.1 external edit |
thinkgeo.mapsuite.webedition.minimapmaptool [2015/09/22 08:49] admin |
====== ThinkGeo.MapSuite.WebEdition.MiniMapMapTool ====== | ====== ThinkGeo.MapSuite.WebEdition.MiniMapMapTool ====== | ||
- | <!-- Class --> | ||
Represents a mini map panel in the lower right corner of the map. | Represents a mini map panel in the lower right corner of the map. | ||
- | === Remarks === | ||
- | The mini map panel is located in the lower right corner of the map and can be expanded or collapsed. It maintains an entire overview of the map even when you have deeply zoomed in. Set the <strong>Enabled</strong> property to true to display it on the map. | ||
===== Inheritance Hierarchy ===== | ===== Inheritance Hierarchy ===== | ||
- | *System.Object | + | *System.Object |
- | **[[ThinkGeo.MapSuite.WebEdition.MapTool]] | + | *ThinkGeo.MapSuite.WebEdition.MapTool |
- | ***[[ThinkGeo.MapSuite.WebEdition.MiniMapMapTool]] | + | ***ThinkGeo.MapSuite.WebEdition.MiniMapMapTool** |
===== Members Summary ===== | ===== Members Summary ===== | ||
==== Public Constructors ==== | ==== Public Constructors ==== | ||
- | ^ Name ^ Parameters ^ DeclaringType ^ Summary ^ | + | ** {{wiki:PublicMethod.gif|}} MiniMapMapTool() ** |
- | | {{wiki:PublicMethod.gif|Public Method}}[[#MiniMapMapTool()|MiniMapMapTool]] | | | Initialize an instance of the MiniMapMapTool class. | | + | |
+ | * //Initialize an instance of the MiniMapMapTool class.// | ||
+ | == Remarks == | ||
+ | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#MiniMapMapTool.28.29// | ||
+ | == Parameters == | ||
+ | <div newline></div> | ||
==== Protected Constructors ==== | ==== Protected Constructors ==== | ||
- | ^ Name ^ Parameters ^ DeclaringType ^ Summary ^ | ||
==== Public Methods ==== | ==== Public Methods ==== | ||
- | ^ Name ^ Parameters ^ DeclaringType ^ Summary ^ | + | ** {{wiki:PublicMethod.gif|}} ToJson() ** |
- | | {{wiki:PublicMethod.gif|Public Method}}[[#Equals(Object)|Equals]] | Object | Object | | | + | |
- | | {{wiki:PublicMethod.gif|Public Method}}[[#GetHashCode()|GetHashCode]] | | Object | | | + | |
- | | {{wiki:PublicMethod.gif|Public Method}}[[#GetType()|GetType]] | | Object | | | + | |
- | | {{wiki:PublicMethod.gif|Public Method}}[[#ToJson()|ToJson]] | | [[ThinkGeo.MapSuite.WebEdition.MapTool|MapTool]] | Returns a JSON string that represents the map control object. | | + | |
- | | {{wiki:PublicMethod.gif|Public Method}}[[#ToString()|ToString]] | | Object | | | + | |
- | ==== Protected Methods ==== | + | * //Returns a JSON string that represents the map control object.// |
- | ^ Name ^ Parameters ^ DeclaringType ^ Summary ^ | + | == Remarks == |
- | | {{wiki:ProtectedMethod.gif|Protected Method}}[[#Finalize()|Finalize]] | | Object | | | + | * //This method returns a JSON string that instructs the client Javascript to create a specific client object.// |
- | | {{wiki:ProtectedMethod.gif|Protected Method}}[[#MemberwiseClone()|MemberwiseClone]] | | Object | | | + | |
- | ==== Public Properties ==== | + | == Return Value == |
- | ^ Name ^ Return ^ DeclaringType ^ Summary ^ | + | * Type:String |
- | | {{wiki:PublicProperty.gif|Public Property}}[[#Enabled|Enabled]] | Boolean | [[ThinkGeo.MapSuite.WebEdition.MapTool|MapTool]] | Gets or sets a value that turns the feature on and off. | | + | * Description:A JSON string that represents the map control. |
- | | {{wiki:PublicProperty.gif|Public Property}}[[#MaximizeRatio|MaximizeRatio]] | Int32 | | The ratio of the mini map resolution to the main map resolution at which to zoom farther out on the mini map. | | + | |
- | | {{wiki:PublicProperty.gif|Public Property}}[[#MinimizeRatio|MinimizeRatio]] | Int32 | | The ratio of the mini map resolution to the main map resolution at which to zoom farther in on the mini map. | | + | |
- | ==== Protected Properties ==== | + | == Parameters == |
- | ^ Name ^ Return ^ DeclaringType ^ Summary ^ | + | <div newline></div> |
+ | ** {{wiki:PublicMethod.gif|}} ToString() ** | ||
- | ==== Public Events ==== | + | * //N/A// |
- | ^ Name ^ Event Arguments ^ DeclaringType ^ Summary ^ | + | == Remarks == |
+ | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#ToString.28.29// | ||
- | ===== Public Constructors ===== | + | == Return Value == |
- | ==== MiniMapMapTool() ==== | + | * Type:String |
- | Initialize an instance of the MiniMapMapTool class. | + | * Description:N/A |
- | === Remarks === | + | |
- | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#MiniMapMapTool.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#MiniMapMapTool.28.29</a> | + | |
- | === Parameters === | + | |
- | ^ Name ^ Type ^ Description ^ | + | |
- | [[#Public Constructors|Go Back]] | + | == Parameters == |
- | ===== Protected Constructors ===== | + | <div newline></div> |
- | ===== Public Methods ===== | + | ** {{wiki:PublicMethod.gif|}} Equals(Object) ** |
- | ==== Equals(Object) ==== | + | |
- | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#Equals.28Object.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#Equals.28Object.29</a> | + | |
- | === Return Value === | + | |
- | ^ Return Type ^ Description ^ | + | |
- | | Boolean<!-- System.Boolean --> | | | + | |
- | === Parameters === | + | * //N/A// |
- | ^ Name ^ Type ^ Description ^ | + | == Remarks == |
- | | obj | Object<!-- System.Object --> | | | + | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#Equals.28Object.29// |
- | <!-- System.Object --> | + | == Return Value == |
- | [[#Public Methods|Go Back]] | + | * Type:Boolean |
- | ==== GetHashCode() ==== | + | * Description:N/A |
- | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#GetHashCode.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#GetHashCode.28.29</a> | + | |
- | | Int32<!-- System.Int32 --> | | | + | |
- | === Parameters === | + | == Parameters == |
- | ^ Name ^ Type ^ Description ^ | + | * //obj// |
+ | * Type:Object | ||
+ | * Description:N/A | ||
- | <!-- System.Object --> | + | <div newline></div> |
- | [[#Public Methods|Go Back]] | + | ** {{wiki:PublicMethod.gif|}} GetHashCode() ** |
- | ==== GetType() ==== | + | |
- | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#GetType.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#GetType.28.29</a> | + | |
- | | Type<!-- System.Type --> | | | + | |
+ | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#GetHashCode.28.29// | ||
- | [[#Public Methods|Go Back]] | + | * Type:Int32 |
- | ==== ToJson() ==== | + | * Description:N/A |
- | Returns a JSON string that represents the map control object. | + | |
- | This method returns a JSON string that instructs the client Javascript to create a specific client object. | + | |
- | | String<!-- System.String --> | A JSON string that represents the map control. | | + | |
- | ^ Name ^ Type ^ Description ^ | + | <div newline></div> |
+ | ** {{wiki:PublicMethod.gif|}} GetType() ** | ||
- | <!-- ThinkGeo.MapSuite.WebEdition.MapTool --> | + | * //N/A// |
- | [[#Public Methods|Go Back]] | + | == Remarks == |
- | ==== ToString() ==== | + | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#GetType.28.29// |
- | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#ToString.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#ToString.28.29</a> | + | |
- | | String<!-- System.String --> | | | + | |
- | === Parameters === | + | == Return Value == |
- | ^ Name ^ Type ^ Description ^ | + | * Type:Type |
- | <!-- System.Object --> | + | == Parameters == |
- | [[#Public Methods|Go Back]] | + | <div newline></div> |
- | ===== Protected Methods ===== | + | ==== Protected Methods ==== |
- | ==== Finalize() ==== | + | ** {{wiki:ProtectedMethod.gif|}} Finalize() ** |
- | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#Finalize.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#Finalize.28.29</a> | + | |
- | | Void<!-- System.Void --> | | | + | |
+ | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#Finalize.28.29// | ||
- | [[#Protected Methods|Go Back]] | + | * Type:Void |
- | ==== MemberwiseClone() ==== | + | * Description:N/A |
- | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#MemberwiseClone.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#MemberwiseClone.28.29</a> | + | |
- | | Object<!-- System.Object --> | | | + | |
+ | ** {{wiki:ProtectedMethod.gif|}} MemberwiseClone() ** | ||
- | <!-- System.Object --> | + | * //N/A// |
- | [[#Protected Methods|Go Back]] | + | == Remarks == |
- | ===== Public Properties ===== | + | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#MemberwiseClone.28.29// |
- | ==== Enabled ==== | + | |
- | Gets or sets a value that turns the feature on and off. | + | == Return Value == |
- | === Remarks === | + | * Type:Object |
- | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#Enabled" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#Enabled</a> | + | * Description:N/A |
- | ^ Return Type ^ | + | == Parameters == |
- | | Boolean<!-- System.Boolean --> | | + | <div newline></div> |
+ | ==== Public Properties ==== | ||
+ | ** {{wiki:PublicProperty.gif|}} MaximizeRatio ** | ||
- | <!-- ThinkGeo.MapSuite.WebEdition.MapTool --> | ||
- | [[#Public Properties|Go Back]] | ||
- | ==== MaximizeRatio ==== | ||
The ratio of the mini map resolution to the main map resolution at which to zoom farther out on the mini map. | The ratio of the mini map resolution to the main map resolution at which to zoom farther out on the mini map. | ||
- | === Remarks === | + | == Remarks == |
- | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#MaximizeRatio" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#MaximizeRatio</a> | + | For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#MaximizeRatio |
- | === Return Value === | + | == Return Value == |
- | ^ Return Type ^ | + | * Type:Int32 |
- | | Int32<!-- System.Int32 --> | | + | |
+ | ** {{wiki:PublicProperty.gif|}} MinimizeRatio ** | ||
- | <!-- ThinkGeo.MapSuite.WebEdition.MiniMapMapTool --> | ||
- | ==== MinimizeRatio ==== | ||
The ratio of the mini map resolution to the main map resolution at which to zoom farther in on the mini map. | The ratio of the mini map resolution to the main map resolution at which to zoom farther in on the mini map. | ||
- | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#MinimizeRatio" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#MinimizeRatio</a> | + | For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#MinimizeRatio |
- | <!-- ThinkGeo.MapSuite.WebEdition.MiniMapMapTool --> | + | ** {{wiki:PublicProperty.gif|}} Enabled ** |
- | [[#Public Properties|Go Back]] | + | |
- | ===== Protected Properties ===== | + | Gets or sets a value that turns the feature on and off. |
- | ===== Public Events ===== | + | == Remarks == |
- | __NOTOC__ | + | For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MiniMapMapTool#Enabled |
- | [[Category:WebEdition]] | + | == Return Value == |
- | [[Category:ThinkGeo.MapSuite.WebEdition]] | + | * Type:Boolean |
- | [[Category:UpdateDocumentation]] | + | |
+ | ==== Protected Properties ==== | ||
+ | ==== Public Events ==== | ||
