<!– Class –> Represents a company logo or other logo-type image that displays in the lower right corner of the map.
The <strong>Logo</strong> map tool represents an image that shows in the lower right corner of the map. Usually you would use this control to display your company logo on the map, similar to a watermark. You need to set the <strong>ImageUri</strong> property to indicate where your company logo file is located.
LogoMapTool | Initialize an instance of the LogoMapTool class. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LogoMapTool#LogoMapTool.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LogoMapTool#LogoMapTool.28.29</a>
Name | Type | Description |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LogoMapTool#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LogoMapTool#Equals.28Object.29</a>
Return Type | Description |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LogoMapTool#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LogoMapTool#GetHashCode.28.29</a>
Int32<!– System.Int32 –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LogoMapTool#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LogoMapTool#GetType.28.29</a>
Type<!– System.Type –> |
Returns a JSON string that represents the map control object.
This method returns a JSON string that instructs the client Javascript to create a specific client object.
String<!– System.String –> | A JSON string that represents the map control. |
<!– ThinkGeo.MapSuite.WebEdition.MapTool –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LogoMapTool#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LogoMapTool#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LogoMapTool#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LogoMapTool#Finalize.28.29</a>
Void<!– System.Void –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LogoMapTool#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LogoMapTool#MemberwiseClone.28.29</a>
Gets or sets a value that turns the feature on and off.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LogoMapTool#Enabled” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LogoMapTool#Enabled</a>
Return Type |
Gets or sets the virtual path of your company logo image.
This property specifies where your company's logo image is. This path is relative to your website root.
Return Type |
Uri<!– System.Uri –> |
<!– ThinkGeo.MapSuite.WebEdition.LogoMapTool –> Go Back
