<!– Class –> Represents a small image that displays at the center of the map when the map is loading.
This map control displays an image at the center of the map, indicating that the map is now busy getting images from the server. Usually the image is in GIF format.
*System.Object ThinkGeo.MapSuite.WebEdition.MapTool *ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool
LoadingImageMapTool | Initialize an instance of LoadingImageMapTool class. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool#LoadingImageMapTool.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool#LoadingImageMapTool.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool#GetType.28.29</a>
Returns a JSON string that represents the map control object.
This method returns a JSON string that instructs the client Javascript to create a specific client object.
| String<!– System.String –> | A JSON string that represents the map control. |
<!– ThinkGeo.MapSuite.WebEdition.MapTool –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool#MemberwiseClone.28.29</a>
Gets or sets a value that turns the feature on and off.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool#Enabled” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool#Enabled</a>
Gets or sets the height of the loading image.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool#Height” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool#Height</a>
<!– ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool –> Go Back
Gets or sets the URI of the loading image.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool#ImageUri” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool#ImageUri</a>
| Uri<!– System.Uri –> |
Gets or sets the width of the loading image.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool#Width” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool#Width</a>
