thinkgeo.mapsuite.webedition.keyboardmaptool
ThinkGeo.MapSuite.WebEdition.KeyboardMapTool
<!– Class –> Determines whether the map can be operated by keyboard.
The &lt;strong&gt;KeyboardMapTool&lt;/strong&gt; map control determines whether you can operate the map by keyboard. Set the &lt;strong&gt;Enabled&lt;/strong&gt; property to true to enable the keyboard support of the map.
Public MethodKeyboardMapTool Initializes a new instance of the KeyboardMapTool class.
Public MethodGetType Object
Public MethodToJson MapTool Returns a JSON string that represents the map control object.
Public MethodToString Object
Public PropertyEnabled Boolean MapTool Gets or sets a value that turns the feature on and off.
Public PropertyPanPixels Int32 Gets or sets the number of pixels that are shifted by each keyboard-based panning operation.
KeyboardMapTool()
Use this constructor to create and initialize a new instance of the &lt;strong&gt;KeyboardMapTool&lt;/strong&gt; class.
Name Type Description
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
ToJson()
This method returns a JSON string that instructs the client Javascript to create a specific client object.
String<!– System.String –> A JSON string that represents the map control.
<!– ThinkGeo.MapSuite.WebEdition.MapTool –> Go Back
Void<!– System.Void –>
Enabled
Return Type
PanPixels
The value of this property determines how many pixels to shift when using the arrow keys to pan.
Return Type
<!– ThinkGeo.MapSuite.WebEdition.KeyboardMapTool –> Go Back
thinkgeo.mapsuite.webedition.keyboardmaptool.1440040135.txt.gz · Last modified: 2015/09/18 03:08 (external edit)
