<!– Class –> Represents a pop up window whose style and background can be customized.
The <strong>CustomPopup</strong> class provides you an easy way to create your customized popup. You can easily change the popup's color and border by specifying the <strong>BackgroundColor</strong>, <strong>BorderColor</strong> and <strong>BorderWidth</strong> properties. Or you can totally change the popup's appearance by putting a background image behind. With the <strong>BackgroundImageVirtualPath</strong> property, you can customize the popup in any shape you like.
CustomPopup | Initialize an instance of the CustomPopup class. | ||
CustomPopup | String | Initialize an instance of the CustomPopup class. | |
CustomPopup | String, PointShape | Initialize an instance of the CustomPopup class. | |
CustomPopup | String, PointShape, String | Initialize an instance of the CustomPopup class. | |
CustomPopup | String, PointShape, String, Int32, Int32 | Initialize an instance of the CustomPopup class. | |
CustomPopup | String, PointShape, String, Int32, Int32, Boolean | Initialize an instance of the CustomPopup class. | |
CustomPopup | String, PointShape, String, Int32, Int32, Boolean, Boolean | Initialize an instance of the CustomPopup class. | |
CustomPopup | String, PointShape, String, Int32, Int32, Boolean, Boolean, Int32 | Initialize an instance of the CustomPopup class. |
CloneShallow | Popup | Creates a shallow copy of the current popup object. | |
ToJson | Popup | Returns a JSON string which contains the popup's information and is used to create the popup at the client side. | |
AutoPan | Boolean | Popup | Gets or sets a value that indicates whether to pan the map to display the entire popup if the popup is not fully displayed. |
AutoSize | Boolean | Popup | Gets or sets a value that indicates whether the popup is automatically resized to fit its contents. |
BackgroundColor | GeoColor | Gets or sets the color applied to the background of the popup object. | |
BackgroundImageVirtualPath | String | Gets or sets the virtual path of the background image. You can set any image as the popup's background. | |
BorderColor | GeoColor | Gets or sets the color applied to the border of the popup object. | |
BorderWidth | Int32 | Gets or sets the width of the popup's border. | |
ContentHtml | String | Gets or sets the content HTML of the popup window. | |
HasCloseButton | Boolean | Popup | Gets or sets a value that indicates whether the popup window has a close button in the upper right corner. |
Height | Int32 | Popup | Gets or sets the height of the popup. |
Id | String | Popup | Gets the identifier by which you can find the popup. |
IsVisible | Boolean | Popup | Gets or sets a value that indicates whether the popup is visible on the map. |
OffsetXInPixels | Int32 | Popup | Gets or sets the popup's pixel offset in X direction. |
OffsetYInPixels | Int32 | Popup | Gets or sets the popup's pixel offset in Y direction. |
Opacity | Single | Popup | Gets or sets the opacity level of the popup. |
Position | PointShape | Popup | Gets or sets a point shape in world coordinates that represents the position of the popup. |
Width | Int32 | Popup | Gets or sets the width of the popup. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#CustomPopup.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#CustomPopup.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#CustomPopup.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#CustomPopup.28String.29</a>
| id | String<!– System.String –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#CustomPopup.28String.2C_PointShape.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#CustomPopup.28String.2C_PointShape.29</a>
| id | String<!– System.String –> | |
| position | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#CustomPopup.28String.2C_PointShape.2C_String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#CustomPopup.28String.2C_PointShape.2C_String.29</a>
| position | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | |
| contentHtml | String<!– System.String –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#CustomPopup.28String.2C_PointShape.2C_String.2C_Int32.2C_Int32.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#CustomPopup.28String.2C_PointShape.2C_String.2C_Int32.2C_Int32.29</a>
| contentHtml | String<!– System.String –> | |
| width | Int32<!– System.Int32 –> | |
| height | Int32<!– System.Int32 –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#CustomPopup.28String.2C_PointShape.2C_String.2C_Int32.2C_Int32.2C_Boolean.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#CustomPopup.28String.2C_PointShape.2C_String.2C_Int32.2C_Int32.2C_Boolean.29</a>
| height | Int32<!– System.Int32 –> | |
| autoPan | Boolean<!– System.Boolean –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#CustomPopup.28String.2C_PointShape.2C_String.2C_Int32.2C_Int32.2C_Boolean.2C_Boolean.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#CustomPopup.28String.2C_PointShape.2C_String.2C_Int32.2C_Int32.2C_Boolean.2C_Boolean.29</a>
| autoPan | Boolean<!– System.Boolean –> | |
| hasCloseButton | Boolean<!– System.Boolean –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#CustomPopup.28String.2C_PointShape.2C_String.2C_Int32.2C_Int32.2C_Boolean.2C_Boolean.2C_Int32.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#CustomPopup.28String.2C_PointShape.2C_String.2C_Int32.2C_Int32.2C_Boolean.2C_Boolean.2C_Int32.29</a>
| hasCloseButton | Boolean<!– System.Boolean –> | |
| borderWidth | Int32<!– System.Int32 –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#CloneShallow.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#CloneShallow.28.29</a>
| Popup<!– ThinkGeo.MapSuite.WebEdition.Popup –> |
<!– ThinkGeo.MapSuite.WebEdition.Popup –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#ToJson.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#ToJson.28.29</a>
| String<!– System.String –> | A string that is used to create the popup at the client side. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#AutoPan” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#AutoPan</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#AutoSize” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#AutoSize</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#BackgroundColor” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#BackgroundColor</a>
| GeoColor<!– ThinkGeo.MapSuite.Core.GeoColor –> |
<!– ThinkGeo.MapSuite.WebEdition.CustomPopup –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#BackgroundImageVirtualPath” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#BackgroundImageVirtualPath</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#BorderColor” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#BorderColor</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#BorderWidth” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#BorderWidth</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#ContentHtml” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#ContentHtml</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#HasCloseButton” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#HasCloseButton</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#Height” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#Height</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#Id” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#Id</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#IsVisible” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#IsVisible</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#OffsetXInPixels” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#OffsetXInPixels</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#OffsetYInPixels” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#OffsetYInPixels</a>
The <strong>Opacity</strong> property enables you to specify a level of transparency for the popup. When this property is set to a value less than 100 percent (1.00), the entire popup (including its content) is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the popup completely invisible.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#Position” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#Position</a>
Gets a string that represents the type of the Popup object.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#PopupType” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CustomPopup#PopupType</a>
<!– ThinkGeo.MapSuite.WebEdition.Popup(overriden) –> Go Back
