thinkgeo.mapsuite.webedition.arcgisserverrestoverlay
ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay
<!– Class –> This class is used to display data from ArcGIS Server 9.3 (and up) Mapping Services using the REST API. More detail on the REST API is available at http://sampleserver1.arcgisonline.com/ArcGIS/SDK/REST/index.html ;specifically, the URL provided to this layer should be an export service URL: http://sampleserver1.arcgisonline.com/ArcGIS/SDK/REST/export.html
Public MethodArcGISServerRestOverlay Initialize an instance of the ArcGISServerRestOverlay class with none parameter.
Public MethodArcGISServerRestOverlay String Initialize an instance of the ArcGISServerRestOverlay class.
Public MethodArcGISServerRestOverlay String, Uri Initialize an instance of the ArcGISServerRestOverlay class.
Public MethodArcGISServerRestOverlay String, Uri, TileType Initialize an instance of the ArcGISServerRestOverlay class.
Public MethodGetType Object
Public MethodToJson Overlay Returns a JSON string which contains the information for creating an overlay at the client side.
Public MethodToString Object
Protected MethodOnTick EventArgs Overlay Raises the Tick event of the MarkerOverlay.
Protected MethodRegisterJavaScriptLibraryCore Page Overlay Registers a Javascript library URL string to the client HTML page.
Public PropertyAttribution String Overlay
Public PropertyAutoRefreshInterval TimeSpan Overlay Gets or sets the time interval in which the MarkerOverlay refreshes itself.
Public PropertyId String Overlay Gets the identifier for the overlay to be found.
Public PropertyIsBaseOverlay Boolean Overlay Gets or sets a value that indicates whether the overlay is a base overlay.
Public PropertyIsVisible Boolean Overlay Gets or sets a value that indicates whether the overlay is visible on the map.
Public PropertyIsVisibleInOverlaySwitcher Boolean Overlay Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher.
Public PropertyName String Overlay Gets or sets the name of the overlay, which will display in the OverlaySwitcher.
Public PropertyOpacity Single Overlay Gets or sets the opacity level of the overlay.
Public PropertyParameters Dictionary<String,String> Gets a dictionary whose items will be passed to the ArcGIS REST Server server as parameters.
Public PropertyProjection String Gets or sets a string that will be sent to the ArcGIS REST server to get the images in the specific projection.
Public PropertyServerUri Uri Gets or sets the URI that specifies the locations of the ArcGIS Rest servers.
Public PropertyTileHeight Int32 Gets or sets the height of each tile, if the WmsOverlay uses tiling.
Public PropertyTileType TileType Gets or sets whether or not the ArcGISServerRestOverlay uses tiling.
Public PropertyTileWidth Int32 Gets or sets the width of each tile, if the WmsOverlay uses tiling.
Public PropertyTransitionEffect TransitionEffect Gets or sets the transition effect to use when the map is zoomed.
Public PropertyTransitionEffectDelayInMilliseconds Int32
Protected PropertyHasTickEvent Boolean Overlay(overriden) Don't support auto tick event by default.
Protected PropertyOverlayType String Overlay(overriden) Gets a string that indicates the overlay type.
Public EventTick EventArgs Overlay Occurs when the number of milliseconds specified in the AutoRefreshInterval property has elapsed and the page is posted to the server.
ArcGISServerRestOverlay()
Name Type Description
Go Back
ArcGISServerRestOverlay(String)
id String<!– System.String –> The identifier string of the ArcGISServerRestOverlay.
Go Back
ArcGISServerRestOverlay(String, Uri)
serverUri Uri<!– System.Uri –> The uri of the ArcGIS REST SERVER
Go Back
ArcGISServerRestOverlay(String, Uri, TileType)
tileType TileType<!– ThinkGeo.MapSuite.WebEdition.TileType –> The Tile Type of the layer
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
ToJson()
String<!– System.String –> A JSON string which is used to create an overlay at the client side.
<!– ThinkGeo.MapSuite.WebEdition.Overlay –> Go Back
Void<!– System.Void –>
OnTick(EventArgs)
e EventArgs<!– System.EventArgs –> An System.EventArgs object that contains the event data.
The &lt;strong&gt;RegisterJavaScriptLibraryCore&lt;/strong&gt; method allows derived classes to override and register their own Javascript library URL to the HTML page.
page Page<!– System.Web.UI.Page –> The page object that is used for registering the javascript library.
Attribution
Return Type
AutoRefreshInterval
Return Type
TimeSpan<!– System.TimeSpan –>
Id
Return Type
IsBaseOverlay
Return Type
IsVisible
Return Type
Return Type
Return Type
Opacity
The &lt;strong&gt;Opacity&lt;/strong&gt; property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
Return Type
Single<!– System.Single –>
Return Type
Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –>
<!– ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay –> Go Back
Projection
Return Type
ServerUri
Return Type
TileHeight
Return Type
TileType
Return Type
TileWidth
Return Type
TransitionEffect
Return Type
TransitionEffect<!– ThinkGeo.MapSuite.WebEdition.TransitionEffect –>
Return Type
HasTickEvent
Return Type
<!– ThinkGeo.MapSuite.WebEdition.Overlay(overriden) –> Go Back
OverlayType
Return Type
Tick
Event Arguments
Event Arguments
NOTOC WebEdition ThinkGeo.MapSuite.WebEdition UpdateDocumentation
thinkgeo.mapsuite.webedition.arcgisserverrestoverlay.1440040135.txt.gz · Last modified: 2015/09/18 03:07 (external edit)
