This is the event arguments for the OverlayDrawing event on the Overlay class. It is raised before the Overlay is drawn.
This is the event arguments for the OverlayDrawing event on the Overlay class. It is raised before the Overlay is drawn. This event allows you to cancel, manipulate the Layer, or draw something with the canvas before the Layers draws. <!– Class –>
*System.Object System.EventArgs *ThinkGeo.MapSuite.WebApiEdition.DrawingOverlayEventArgs
![]() | This is a constructor for the class. | ||
![]() | GeoCanvas | This is a constructor for the class. | |
![]() | GeoCanvas, Boolean | This is a constructor for the class. |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Object | ||
![]() | Object |
This is the default constructor. If you use this constructor then you need to set the required properties manually.
Name | Type | Description |
This constructor allows you to set the Overlay to be drawn, the world extent and the image you are drawing on.
This is the constructor with a GeoCanvas where we will draw the map.
geoCanvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | This parameter is the GeoCanvas that have drawn. |
cancel | Boolean<!– System.Boolean –> | This parameter is a value that determines whether you want to cancel the Overlay from drawing. |
Return Type | Description |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
String<!– System.String –> |
Void<!– System.Void –> |
This property gets and sets a value that determines whether you want to cancel the Overlay from drawing
Return Type |
<!– ThinkGeo.MapSuite.WebApiEdition.DrawingOverlayEventArgs –> Go Back
This property gets and sets the GeoCanvas we are drawing on.
Return Type |
