thinkgeo.mapsuite.silverlightedition.vertexremovingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.SilverlightEdition.VertexRemovingEditInteractiveOverlayEventArgs
<!– Class –> Provides data for the VertexRemoving. event.
Public MethodVertexRemovingEditInteractiveOverlayEventArgs This is the default constructor of this parameter.
Public MethodVertexRemovingEditInteractiveOverlayEventArgs Boolean, Feature, Vertex This is the commonly used constructor.
Public MethodGetType Object
Public MethodToString Object
Public PropertyAffectedVertexFeature Feature This property gets or sets the Feature to be used to remove vertex.
Public PropertyCancel Boolean This property gets or sets the action to be canceled or not.
Public PropertyRemovingVertex Vertex This property gets or sets the vertex to be removed.
VertexRemovingEditInteractiveOverlayEventArgs()
Name Type Description
Go Back
VertexRemovingEditInteractiveOverlayEventArgs(Boolean, Feature, Vertex)
cancel Boolean<!– System.Boolean –> This parameter specified the cancel property.
affectedVertexFeature Feature<!– ThinkGeo.MapSuite.SilverlightCore.Feature –> This parameter specified the affectedVertex feature property.
removingVertex Vertex<!– ThinkGeo.MapSuite.SilverlightCore.Vertex –> This parameter specified the target vertex to be removed.
Go Back
Return Type Description
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
Return Type
<!– ThinkGeo.MapSuite.SilverlightEdition.VertexRemovingEditInteractiveOverlayEventArgs –> Go Back
Cancel
Return Type
RemovingVertex
Return Type
thinkgeo.mapsuite.silverlightedition.vertexremovingeditinteractiveoverlayeventargs.1440040135.txt.gz · Last modified: 2015/09/21 03:30 (external edit)
