<!– Class –> Provides data for the VertexMoving. event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.SilverlightEdition.VertexMovingEditInteractiveOverlayEventArgs
![]() | This is the default constructor of this parameter. | ||
![]() | Boolean, Feature, Vertex | This is the commonly used constructor. |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Object | ||
![]() | Object |
![]() | Feature | This property gets or sets the Feature to be used to move vertex. | |
![]() | Boolean | This property gets or sets the action to be canceled or not. | |
![]() | Vertex | This property gets or sets the vertex to be moved. |
Name | Type | Description |
cancel | Boolean<!– System.Boolean –> | This parameter specified the cancel property. |
affectedVertexFeature | Feature<!– ThinkGeo.MapSuite.SilverlightCore.Feature –> | This parameter specified the affectedVertex feature property. |
movingVertex | Vertex<!– ThinkGeo.MapSuite.SilverlightCore.Vertex –> | This parameter specified the target vertex to be moved. |
Return Type | Description |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
String<!– System.String –> |
Void<!– System.Void –> |
Return Type |
<!– ThinkGeo.MapSuite.SilverlightEdition.VertexMovingEditInteractiveOverlayEventArgs –> Go Back
Return Type |
Return Type |
