<!– Class –> Provides data for the VertexMoved. event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.SilverlightEdition.VertexMovedEditInteractiveOverlayEventArgs
VertexMovedEditInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
VertexMovedEditInteractiveOverlayEventArgs | Feature, Vertex | This is the commonly used constructor. |
AffectedVertexFeature | Feature | This property gets or sets the Feature to be used to remove vertex. | |
MovedVertex | Vertex | This property gets or sets the vertex moved. |
| Feature<!– ThinkGeo.MapSuite.SilverlightCore.Feature –> |
<!– ThinkGeo.MapSuite.SilverlightEdition.VertexMovedEditInteractiveOverlayEventArgs –> Go Back
| Vertex<!– ThinkGeo.MapSuite.SilverlightCore.Vertex –> |
