thinkgeo.mapsuite.silverlightedition.vertexaddedtrackinteractiveoverlayeventargs
ThinkGeo.MapSuite.SilverlightEdition.VertexAddedTrackInteractiveOverlayEventArgs
Provides data for the VertexAdded. event.
      • ThinkGeo.MapSuite.SilverlightEdition.VertexAddedTrackInteractiveOverlayEventArgs
VertexAddedTrackInteractiveOverlayEventArgs()
VertexAddedTrackInteractiveOverlayEventArgs(Vertex,Feature)
  • addedVertex
    • Type:Vertex
    • Description:This parameter specified the vertex is added.
  • affectedFeature
    • Type:Feature
    • Description:This parameter specified the feature to be used to add vertex on when tracking shape.
AddedVertex
This property gets or sets the vertex added.
AffectedFeature
This property gets or sets the Feature with vertex added.
thinkgeo.mapsuite.silverlightedition.vertexaddedtrackinteractiveoverlayeventargs.1442806194.txt.gz · Last modified: 2015/09/21 03:29 by admin
