thinkgeo.mapsuite.silverlightedition.vertexaddededitinteractiveoverlayeventargs
ThinkGeo.MapSuite.SilverlightEdition.VertexAddedEditInteractiveOverlayEventArgs
Provides data for the VertexAdded. event.
      • ThinkGeo.MapSuite.SilverlightEdition.VertexAddedEditInteractiveOverlayEventArgs
VertexAddedEditInteractiveOverlayEventArgs()
VertexAddedEditInteractiveOverlayEventArgs(Feature,Vertex)
  • affectedVertexFeature
    • Type:Feature
    • Description:This parameter specified the affectedVertex feature property.
  • addedVertex
    • Type:Vertex
    • Description:This parameter specified the target vertex added.
AffectedVertexFeature
This property gets or sets the Feature to be used to remove vertex.
AddedVertex
This property gets or sets the vertex added.
thinkgeo.mapsuite.silverlightedition.vertexaddededitinteractiveoverlayeventargs.1442806192.txt.gz · Last modified: 2015/09/21 03:29 by admin
