thinkgeo.mapsuite.silverlightedition.trackstartingtrackinteractiveoverlayeventargs
thinkgeo.mapsuite.silverlightedition.trackstartingtrackinteractiveoverlayeventargs [2015/09/21 03:29]
thinkgeo.mapsuite.silverlightedition.trackstartingtrackinteractiveoverlayeventargs [2017/03/16 21:59] (current)
 ====== ThinkGeo.MapSuite.SilverlightEdition.TrackStartingTrackInteractiveOverlayEventArgs ====== ====== ThinkGeo.MapSuite.SilverlightEdition.TrackStartingTrackInteractiveOverlayEventArgs ======
 +{{section>​upgrade_map_suite_to_10.0}}
 Provides data for the TrackStarting. event. Provides data for the TrackStarting. event.
 ===== Inheritance Hierarchy ===== ===== Inheritance Hierarchy =====
Line 9: Line 12:
 ** {{wiki:​PublicMethod.gif|}} TrackStartingTrackInteractiveOverlayEventArgs() ** ** {{wiki:​PublicMethod.gif|}} TrackStartingTrackInteractiveOverlayEventArgs() **
-This is the default constructor of this parameter.+  * //This is the default constructor of this parameter.//
 == Remarks == == Remarks ==
-If you use this constructor,​ you have to set the properties manually before use.+  * //If you use this constructor,​ you have to set the properties manually before use.//
 == Parameters == == Parameters ==
 <div newline></​div>​ <div newline></​div>​
 ** {{wiki:​PublicMethod.gif|}} TrackStartingTrackInteractiveOverlayEventArgs(Vertex,​Boolean) ** ** {{wiki:​PublicMethod.gif|}} TrackStartingTrackInteractiveOverlayEventArgs(Vertex,​Boolean) **
-This is the commonly used constructor.+  * //This is the commonly used constructor.//
-N/A+  * //N/A//
   * //​startingVertex//​   * //​startingVertex//​
Line 33: Line 36:
 ** {{wiki:​PublicMethod.gif|}} ToString() ** ** {{wiki:​PublicMethod.gif|}} ToString() **
-N/A+  * //N/A//
-N/A+  * //N/A//
 == Return Value == == Return Value ==
Line 45: Line 48:
 ** {{wiki:​PublicMethod.gif|}} Equals(Object) ** ** {{wiki:​PublicMethod.gif|}} Equals(Object) **
-N/A+  * //N/A//
-N/A+  * //N/A//
Line 61: Line 64:
 ** {{wiki:​PublicMethod.gif|}} GetHashCode() ** ** {{wiki:​PublicMethod.gif|}} GetHashCode() **
-N/A+  * //N/A//
-N/A+  * //N/A//
Line 73: Line 76:
 ** {{wiki:​PublicMethod.gif|}} GetType() ** ** {{wiki:​PublicMethod.gif|}} GetType() **
-N/A+  * //N/A//
-N/A+  * //N/A//
Line 86: Line 89:
 ** {{wiki:​ProtectedMethod.gif|}} Finalize() ** ** {{wiki:​ProtectedMethod.gif|}} Finalize() **
-N/A+  * //N/A//
-N/A+  * //N/A//
Line 98: Line 101:
 ** {{wiki:​ProtectedMethod.gif|}} MemberwiseClone() ** ** {{wiki:​ProtectedMethod.gif|}} MemberwiseClone() **
-N/A+  * //N/A//
-N/A+  * //N/A//
thinkgeo.mapsuite.silverlightedition.trackstartingtrackinteractiveoverlayeventargs.1442806188.txt.gz ยท Last modified: 2015/09/21 03:29 by admin
