thinkgeo.mapsuite.silverlightedition.mousemovedtrackinteractiveoverlayeventargs
ThinkGeo.MapSuite.SilverlightEdition.MouseMovedTrackInteractiveOverlayEventArgs
Provides data for the MouseMoved. event.
      • ThinkGeo.MapSuite.SilverlightEdition.MouseMovedTrackInteractiveOverlayEventArgs
MouseMovedTrackInteractiveOverlayEventArgs()
MouseMovedTrackInteractiveOverlayEventArgs(Vertex,Feature)
  • movedVertex
    • Type:Vertex
    • Description:This parameter specified the target vertex to be moved.
  • affectedFeature
    • Type:Feature
    • Description:This parameter specified the affected feature.
MovedVertex
This property gets or sets the vertex to be moved.
AffectedFeature
This property gets or sets the Feature to be affected.
thinkgeo.mapsuite.silverlightedition.mousemovedtrackinteractiveoverlayeventargs.1442806148.txt.gz · Last modified: 2015/09/21 03:29 by admin
