thinkgeo.mapsuite.silverlightedition.mapmousemoveinteractiveoverlayeventargs
ThinkGeo.MapSuite.SilverlightEdition.MapMouseMoveInteractiveOverlayEventArgs
Provides data for the MapMouseMove event.
      • ThinkGeo.MapSuite.SilverlightEdition.MapMouseMoveInteractiveOverlayEventArgs
MapMouseMoveInteractiveOverlayEventArgs()
MapMouseMoveInteractiveOverlayEventArgs(Feature,ControlPointType)
  • editingFeature
    • Type:Feature
    • Description:This parameter specified the editing feature to construct the class.
  • controlPointType
    • Description:This parameter specified the controlPointType to construct the class.
ControlPointType
This property gets the ControlPointType for the event args.
EditingFeature
This property gets the EditingFeature for the event args.
thinkgeo.mapsuite.silverlightedition.mapmousemoveinteractiveoverlayeventargs.1442911136.txt.gz · Last modified: 2015/09/22 08:38 by admin
