<!– Class –> Provides data for the MapMouseMove event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.SilverlightEdition.MapMouseMoveInteractiveOverlayEventArgs
![]() | This is the default constructor of this parameter. | ||
![]() | Feature, ControlPointType | This is the commonly used constructor. |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Object | ||
![]() | Object |
![]() | ControlPointType | This property gets the ControlPointType for the event args. | |
![]() | Feature | This property gets the EditingFeature for the event args. |
Name | Type | Description |
editingFeature | Feature<!– ThinkGeo.MapSuite.SilverlightCore.Feature –> | This parameter specified the editing feature to construct the class. |
controlPointType | ControlPointType<!– ThinkGeo.MapSuite.SilverlightEdition.ControlPointType –> | This parameter specified the controlPointType to construct the class. |
Return Type | Description |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
String<!– System.String –> |
Void<!– System.Void –> |
Return Type |
<!– ThinkGeo.MapSuite.SilverlightEdition.MapMouseMoveInteractiveOverlayEventArgs –> Go Back
Return Type |
