<!– Class –> Provides data for the MapMouseDown event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.SilverlightEdition.MapMouseDownInteractiveOverlayEventArgs
MapMouseDownInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
MapMouseDownInteractiveOverlayEventArgs | InteractionArguments | This is the commonly used constructor. |
InteractionArguments | InteractionArguments | This property gets the interaction auguments for the event args. |
| interactionArguments | InteractionArguments<!– ThinkGeo.MapSuite.SilverlightEdition.InteractionArguments –> | This parameter specified the interaction auguments to construct the class. |
<!– ThinkGeo.MapSuite.SilverlightEdition.MapMouseDownInteractiveOverlayEventArgs –> Go Back
