thinkgeo.mapsuite.silverlightedition.interactionarguments
ThinkGeo.MapSuite.SilverlightEdition.InteractionArguments
This class encapsulates the information and simple method for interative actions.
    • ThinkGeo.MapSuite.SilverlightEdition.InteractionArguments
InteractionArguments()
Override the ToString API for object.
  • Description:Returns a string to mark this instance and easy to read its properties.
ScreenX
This property gets or sets the screen X position.
  • Type:Single
ScreenY
This property gets or sets the screen Y position.
  • Type:Single
WorldX
This property gets or sets the world X position.
WorldY
This property gets or sets the world Y position.
CurrentExtent
This property gets or sets the current extent used in the MapControl.
SearchingTolerance
This property gets or sets the searching tolearance for tracking and editing.
MapWidth
This property gets or sets the with for the Map Control.
MapHeight
This property gets or sets the height for the Map Control.
MapUnit
This property gets or sets the unit for the Map Control.
ZoomLevelSet
This property gets or sets the ZoomLevelSet used in the Map Control.
MouseWheelDelta
This property gets or sets the Mouse wheel delta used in the MouseWheel method in InterativeOverlay.
Scale
This property gets or sets the scale in current status.
thinkgeo.mapsuite.silverlightedition.interactionarguments.1442806088.txt.gz · Last modified: 2015/09/21 03:28 by admin
