<!– Class –> This class encapsulates the information and simple method for interative actions.
*System.Object **ThinkGeo.MapSuite.SilverlightEdition.InteractionArguments
InteractionArguments | This is the default constructor of this parameter. |
ToString | Object(overriden) | Override the ToString API for object. |
CurrentExtent | RectangleShape | This property gets or sets the current extent used in the MapControl. | |
MapHeight | Int32 | This property gets or sets the height for the Map Control. | |
MapUnit | GeographyUnit | This property gets or sets the unit for the Map Control. | |
MapWidth | Int32 | This property gets or sets the with for the Map Control. | |
MouseWheelDelta | Int32 | This property gets or sets the Mouse wheel delta used in the MouseWheel method in InterativeOverlay. | |
Scale | Double | This property gets or sets the scale in current status. | |
ScreenX | Single | This property gets or sets the screen X position. | |
ScreenY | Single | This property gets or sets the screen Y position. | |
SearchingTolerance | Double | This property gets or sets the searching tolearance for tracking and editing. | |
WorldX | Double | This property gets or sets the world X position. | |
WorldY | Double | This property gets or sets the world Y position. | |
ZoomLevelSet | ZoomLevelSet | This property gets or sets the ZoomLevelSet used in the Map Control. |
| String<!– System.String –> | Returns a string to mark this instance and easy to read its properties. |
| RectangleShape<!– ThinkGeo.MapSuite.SilverlightCore.RectangleShape –> |
<!– ThinkGeo.MapSuite.SilverlightEdition.InteractionArguments –> Go Back
| GeographyUnit<!– ThinkGeo.MapSuite.SilverlightCore.GeographyUnit –> |
| ZoomLevelSet<!– ThinkGeo.MapSuite.SilverlightCore.ZoomLevelSet –> |
