<!– Class –> Provides data for the FeatureResizing. event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.SilverlightEdition.FeatureResizingEditInteractiveOverlayEventArgs
FeatureResizingEditInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
FeatureResizingEditInteractiveOverlayEventArgs | Feature, Boolean, PointShape, PointShape | This is the commonly used constructor. |
Cancel | Boolean | This property gets or sets the action to be canceled or not. | |
ResizingFeature | Feature | This property gets or sets the Feature to be used to resized. | |
SourceControlPoint | PointShape | This property gets or sets the source control point to resize. | |
TargetControlPoint | PointShape | This property gets or sets the target control point to resize. |
| resizingFeature | Feature<!– ThinkGeo.MapSuite.SilverlightCore.Feature –> | This parameter specified the target feature to be resized. |
| cancel | Boolean<!– System.Boolean –> | This parameter specified the cancel property. |
| sourceControlPoint | PointShape<!– ThinkGeo.MapSuite.SilverlightCore.PointShape –> | This parameter specified the source control point to be resized. |
| targetControlPoint | PointShape<!– ThinkGeo.MapSuite.SilverlightCore.PointShape –> | This parameter specified the target control point to be resized. |
<!– ThinkGeo.MapSuite.SilverlightEdition.FeatureResizingEditInteractiveOverlayEventArgs –> Go Back
