<!– Class –> Provides data for the FeatureResized. event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.SilverlightEdition.FeatureResizedEditInteractiveOverlayEventArgs
FeatureResizedEditInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
FeatureResizedEditInteractiveOverlayEventArgs | Feature | This is the commonly used constructor. |
ResizedFeature | Feature | This property gets or sets the Feature resized. |
| resizedFeature | Feature<!– ThinkGeo.MapSuite.SilverlightCore.Feature –> | This parameter specified the feature resized. |
<!– ThinkGeo.MapSuite.SilverlightEdition.FeatureResizedEditInteractiveOverlayEventArgs –> Go Back
