<!– Class –> Provides data for the FeatureDragged event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.SilverlightEdition.FeatureDraggedEditInteractiveOverlayEventArgs
FeatureDraggedEditInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
FeatureDraggedEditInteractiveOverlayEventArgs | Feature | This is the commonly used constructor. |
DraggedFeature | Feature | This property gets or sets the Feature dragged. |
| draggedFeature | Feature<!– ThinkGeo.MapSuite.SilverlightCore.Feature –> | This parameter specified the feature dragged. |
<!– ThinkGeo.MapSuite.SilverlightEdition.FeatureDraggedEditInteractiveOverlayEventArgs –> Go Back
