thinkgeo.mapsuite.silverlightedition.controlpointselectingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.SilverlightEdition.ControlPointSelectingEditInteractiveOverlayEventArgs
      • ThinkGeo.MapSuite.SilverlightEdition.ControlPointSelectingEditInteractiveOverlayEventArgs
ControlPointSelectingEditInteractiveOverlayEventArgs()
ControlPointSelectingEditInteractiveOverlayEventArgs(Boolean,PointShape)
  • cancel
  • targetPointShape
    • Description:This parameter specified the target control point to be selected.
TargetPointShape
This property gets or sets the target control point to be selected.
Cancel
thinkgeo.mapsuite.silverlightedition.controlpointselectingeditinteractiveoverlayeventargs.1442806050.txt.gz · Last modified: 2015/09/21 03:27 by admin
