<!– Class –> Provides data for the ControlPointSelecting event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.SilverlightEdition.ControlPointSelectingEditInteractiveOverlayEventArgs
ControlPointSelectingEditInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
ControlPointSelectingEditInteractiveOverlayEventArgs | Boolean, PointShape | This is the commonly used constructor. |
Cancel | Boolean | This property gets or sets the action to be canceled or not. | |
TargetPointShape | PointShape | This property gets or sets the target control point to be selected. |
| cancel | Boolean<!– System.Boolean –> | This parameter specified the cancel property. |
| targetPointShape | PointShape<!– ThinkGeo.MapSuite.SilverlightCore.PointShape –> | This parameter specified the target control point to be selected. |
<!– ThinkGeo.MapSuite.SilverlightEdition.ControlPointSelectingEditInteractiveOverlayEventArgs –> Go Back
