<!– Class –> Provides data for the ControlPointSelected event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.SilverlightEdition.ControlPointSelectedEditInteractiveOverlayEventArgs
ControlPointSelectedEditInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
ControlPointSelectedEditInteractiveOverlayEventArgs | Feature | This is the commonly used constructor. |
SelectedFeature | Feature | This property gets or sets the selected feature. |
| selectedFeature | Feature<!– ThinkGeo.MapSuite.SilverlightCore.Feature –> | This parameter specified the feature selected. |
<!– ThinkGeo.MapSuite.SilverlightEdition.ControlPointSelectedEditInteractiveOverlayEventArgs –> Go Back
