thinkgeo.mapsuite.silverlightcore.degreesminutesseconds
ThinkGeo.MapSuite.SilverlightCore.DegreesMinutesSeconds
This structure represents a degrees, minutes and seconds value.
    • System.ValueType
      • ThinkGeo.MapSuite.SilverlightCore.DegreesMinutesSeconds
DegreesMinutesSeconds(Int32,Int32,Double)
This constructor allows you to create an instance of the class by specifying the degree, minute and second values.
  • degrees
    • Description:This parameter represents the degree portion of the structure.
  • minutes
    • Description:This parameter represents the minute portion of the structure.
  • seconds
    • Description:This parameter represents the second portion of the structure.
Serves as hash function for the particular type.
  • Description:The hash code for this particular type.
Compares current DegreesMinutesSeconds with a passing object.
  • Description:True if the passing object satisfies the following two conditions:1) The object is of DegreesMinutesSeconds type.2) The Degrees, Minutes and Seconds of both DegreesMinutesSeconds should be the same.If both conditions are not met, will return false.
    • Description:The passing object which will be used to compare with current DegreesMinutesSeconds.
Add(DegreesMinutesSeconds)
Add two DegreesMinutsSeconds together and return back a summary of the two.
  • targetDegreesMinutesSeconds
This method returns a formatted representation of the degrees, minutes and seconds value.
The value will be formatted in the standard string format: 75º 21' 28“
  • Description:This method returns a formatted representation of the degrees, minutes and seconds value.
ToString(Int32)
This method returns a formatted representation of the degrees, minutes and seconds value that has been rounded to the specified decimals.
The value will be formatted in the standard string format. For example, 75º 21' 2.1235” (when the decimals parameter is set to 4).
  • decimals
    • Description:The target decimals that the degrees, minutes, seconds value will be rounded to.
Degrees
This property returns the degrees portion of the structure.
Minutes
This property returns the minutes portion of the structure.
Seconds
This property returns the seconds portion of the structure.
thinkgeo.mapsuite.silverlightcore.degreesminutesseconds.1442805593.txt.gz · Last modified: 2015/09/21 03:19 by admin
