thinkgeo.mapsuite.silverlightcore.backgroundlayer
ThinkGeo.MapSuite.SilverlightCore.BackgroundLayer
This class draws the background of the map.
    • ThinkGeo.MapSuite.SilverlightCore.Layer
      • ThinkGeo.MapSuite.SilverlightCore.BackgroundLayer
BackgroundLayer()
This is the default constructor for the class.
BackgroundLayer(GeoBrush)
  • backgroundBrush
    • Type:GeoBrush
    • Description:This parameter is the brush that will be used draw the background layer.
Open()
Close()
GetBoundingBox()
This method will draw the background layer based on the parameters provided.
  • Description:None
  • canvas
    • Type:GeoCanvas
    • Description:This parameter is the GeoCanvas used to Draw the layer.
  • labelsInAllLayers
    • Description:This parameter is not used for BackgroundLayers.
OpenCore()
CloseCore()
GetBoundingBoxCore()
  • e
    • Type:Exception
  • e
    • Type:Exception
BackgroundBrush
This property gets and sets the brush for this background layer.
IsOpen
HasBoundingBox
DrawingTime
  • Type:TimeSpan
IsVisible
DrawingExceptionMode
IsOpenCore
DrawingProgressChanged N/A
thinkgeo.mapsuite.silverlightcore.backgroundlayer.1442805549.txt.gz · Last modified: 2015/09/21 03:19 by admin
