thinkgeo.mapsuite.portablecore.xmlgeoserializationformatter
ThinkGeo.MapSuite.Core.XmlGeoSerializationFormatter
This class formats a GeoObjectModel into XML.
    • ThinkGeo.MapSuite.Core.GeoSerializationFormatter
      • ThinkGeo.MapSuite.Core.XmlGeoSerializationFormatter
XmlGeoSerializationFormatter()
Creates an instance of GeoSerializationFormatter.
Save(GeoObjectModel,Stream)
  • stream
    • Type:Stream
Load(Stream)
  • stream
    • Type:Stream
SaveCore(GeoObjectModel,Stream)
Format a GeoObjectModel into XML, and save the XML into a stream.
  • model
    • Description:The GeoObjectModel to create XML for.
  • stream
    • Type:Stream
    • Description:The Stream to save XML into.
LoadCore(Stream)
Load a stream that contains XML into a GeoObjectModel.
  • Description:The GeoObjectModel recreated from the stream.
  • stream
    • Type:Stream
    • Description:The Stream that contains XML.
Encoding
  • Type:Encoding
thinkgeo.mapsuite.portablecore.xmlgeoserializationformatter.1442823716.txt.gz · Last modified: 2015/09/21 08:21 by admin
