<!– Class –> This class formats a GeoObjectModel into XML.
*System.Object ThinkGeo.MapSuite.PortableCore.GeoSerializationFormatter *ThinkGeo.MapSuite.PortableCore.XmlGeoSerializationFormatter
XmlGeoSerializationFormatter | Creates an instance of GeoSerializationFormatter. |
Load | Stream | GeoSerializationFormatter | Load a stream into a GeoObjectModel. |
Save | GeoObjectModel, Stream | GeoSerializationFormatter | Save serialized data into a stream. |
LoadCore | Stream | GeoSerializationFormatter(overriden) | Load a stream that contains XML into a GeoObjectModel. |
MemberwiseClone | Object | ||
SaveCore | GeoObjectModel, Stream | GeoSerializationFormatter(overriden) | Format a GeoObjectModel into XML, and save the XML into a stream. |
Encoding | Encoding | GeoSerializationFormatter | set or get the readEncoding. |
| GeoObjectModel<!– ThinkGeo.MapSuite.PortableCore.GeoObjectModel –> | The GeoObjectModel recreated from the stream. |
| stream | Stream<!– System.IO.Stream –> | The Stream to load from. |
<!– ThinkGeo.MapSuite.PortableCore.GeoSerializationFormatter –> Go Back
| model | GeoObjectModel<!– ThinkGeo.MapSuite.PortableCore.GeoObjectModel –> | The GeoObjectModel to create serialized data for. |
| stream | Stream<!– System.IO.Stream –> | The Stream to save serialized data into. |
| stream | Stream<!– System.IO.Stream –> | The Stream that contains XML. |
<!– ThinkGeo.MapSuite.PortableCore.GeoSerializationFormatter(overriden) –> Go Back
| model | GeoObjectModel<!– ThinkGeo.MapSuite.PortableCore.GeoObjectModel –> | The GeoObjectModel to create XML for. |
| stream | Stream<!– System.IO.Stream –> | The Stream to save XML into. |
| Encoding<!– System.Text.Encoding –> |
