This class is use for world map kit, and you also can get map from ThinkGeo world map kit server.
The constructor initilizes the properties. UpperThreshold is set to double.MaxValue, LowerThreshold is set to double.MinValue.
WorldMapKitLayer(String,String)
This is the constructor the for the class.
This constructor initializes a new layer and assgin a license key.
WorldMapKitLayer(WorldMapKitLayerType,String,String)
WorldMapKitLayer(WorldMapKitLayerType,WebProxy,String,String)
None.
None.
None.
This method returns the projected or geographic coordinate reference systems to be used.
None.
This abstract method is called from the concrete public method Close. The close method plays an important role in the life cycle of the Layer. It may be called after drawing to release any memory and other resources that were allocated since the Open method was called. If you override this method, it is recommended that you take the following things into account: This method may be called multiple times, so we suggest you write the method so that that a call to a closed Layer is ignored and does not generate an error. We also suggest that in the Close you free all resources that have been opened. Remember that the object will not be destroyed, but will be re-opened possibly in the near future.
DrawImage(GeoCanvas,Collection<SimpleCandidate>)
This method draws image on the canvas with specified labelsInAllLayers
This method draws the Layer.
This method is the concrete wrapper for the abstract method DrawCore. This method draws the representation of the layer based on the extent you provided. When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
VSw=(RectangleShape,RectangleShape)
IsExtentWithinThreshold(RectangleShape,Double,Double,Int32,GeographyUnit)
This method retures a value represents whether the currentExtent is within the passing in thresholds.
IsExtentWithinThreshold(RectangleShape,Double,Double,Int32,GeographyUnit,Single)
Gets or sets a value that is unique to your client ID, please keep your key secure.
Gets or sets a WorldMapKitProjection represents which projection will be use.
This property gets or sets the proxy used for requesting a Web Response.
Is the current scale is beyond this value, the map will not render.
Is the current scale is less than this value, the map will not render.
This property specifies the timeout of the web request in seconds. The default timeout value is 20 seconds.
This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs.
The value of WorldMapKitLayer is false.
This property returns true if the Layer is open and false if it is not.
Various methods on the Layer require that it be in an open state. If one of those methods is called when the state is not open, then the method will throw an exception. To enter the open state, you must call the Layer Open method. The method will raise an exception if the current Layer is already open.
