<!– Class –> This class is use for world map kit, and you also can get map from ThinkGeo world map kit server.
*System.Object ThinkGeo.MapSuite.PortableCore.Layer *ThinkGeo.MapSuite.PortableCore.WorldMapKitLayer
![]() | The default constructor | ||
![]() | String, String | This is the constructor the for the class. |
![]() | This method clears the tile cache. | ||
![]() | Layer | Create a copy of Layer using the deep clone process. | |
![]() | Layer | This method closes the Layer and releases any resources it was using. | |
![]() | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
![]() | Object | Object | |
![]() | Layer | This method returns the bounding box of the Layer. | |
![]() | Object | ||
![]() | RectangleShape, Int32, Int32 | Get the request URLs from the client to the WMS servers. | |
![]() | This method returns the projected or geographic coordinate reference systems to be used. | ||
![]() | This method returns the exception format at the server side. | ||
![]() | This method returns the names of all layers at the server side. | ||
![]() | This method returns the output format at the server side. | ||
![]() | This method returns the names of all styles at the server side. | ||
![]() | This API gets the WMS server version of the service. | ||
![]() | Object | ||
![]() | Layer | This method opens the Layer so that it is initialized and ready to use. | |
![]() | Layer | ||
![]() | RectangleShape | Layer | |
![]() | IEnumerable<RectangleShape> | Layer | |
![]() | TimeSpan | Layer | |
![]() | IEnumerable<RectangleShape>, TimeSpan | Layer | |
![]() | RectangleShape, TimeSpan | Layer | |
![]() | Object |
![]() | Layer | Create a copy of Layer using the deep clone process. The default implemenation uses serialization. | |
![]() | Layer(overriden) | This method closes the Layer and releases any resources it was using. | |
![]() | GeoCanvas, String | Layer | |
![]() | GeoCanvas, Collection<SimpleCandidate> | Layer(overriden) | This method draws the Layer. |
![]() | GeoCanvas, Exception | Layer | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
![]() | GeoCanvas, Exception | Layer(overriden) | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
![]() | GeoCanvas, Collection<SimpleCandidate> | This method draws image on the canvas with specified labelsInAllLayers | |
![]() | Object | ||
![]() | Layer(overriden) | ||
![]() ![]() | RectangleShape, Double, Double, Int32, GeographyUnit | This method retures a value represents whether the currentExtent is within the passing in thresholds. | |
![]() ![]() | RectangleShape, Double, Double, Int32, GeographyUnit, Single | This method retures a value represents whether the currentExtent is within the passing in thresholds. | |
![]() | Object | ||
![]() | DrawingAttributionLayerEventArgs | Layer | |
![]() | DrawingExceptionLayerEventArgs | Layer | |
![]() | DrawingProgressChangedEventArgs | Layer | |
![]() | DrawnAttributionLayerEventArgs | Layer | |
![]() | DrawnExceptionLayerEventArgs | Layer | |
![]() | RequestedDrawingLayerEventArgs | Layer | |
![]() | RequestingDrawingLayerEventArgs | Layer | |
![]() | SendingWebRequestEventArgs | ||
![]() | SentWebRequestEventArgs | ||
![]() | Layer(overriden) | This method opens the Layer so that it is initialized and ready to use. |
![]() | String | Layer | |
![]() | String | Gets or sets a value that is your Client Id. | |
![]() | DrawingExceptionMode | Layer | Gets or sets the DrawExcpetionMode when exception happens. |
![]() | TimeSpan | Layer | This property gets the last drawing time for the layer. |
![]() | Boolean | Layer(overriden) | This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. |
![]() | Boolean | Layer | This property gets and sets if the image should be converted to grayscale. |
![]() | Boolean | Layer | This property gets and sets whether the image should be converted to negative (inverse colors). |
![]() | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
![]() | Boolean | Layer | This property gets and set the visible state of the layer. |
![]() | WorldMapKitLayerType | ||
![]() | Double | Gets or sets a value represents lower threshold for scale. | |
![]() | String | Layer | This property gets and sets the name for the layer. |
![]() | String | Gets or sets a value that is unique to your client ID, please keep your key secure. | |
![]() | WorldMapKitProjection | ||
![]() | GeoWebProxy | This property gets or sets the proxy used for requesting a Web Response. | |
![]() | BitmapTileCache | Gets or sets a BitmapTileCache represents which tile cache will be use. | |
![]() | Int32 | This property specifies the timeout of the web request in seconds. The default timeout value is 20 seconds. | |
![]() | Single | Layer | This property gets and sets the amount of transparency to apply to the image. |
![]() | Double | Gets or sets a value represents upper threshold for scale. |
![]() | Boolean | Layer(overriden) | This property returns true if the Layer is open and false if it is not. |
The constructor initilizes the properties. UpperThreshold is set to double.MaxValue, LowerThreshold is set to double.MinValue.
Name | Type | Description |
This constructor initializes a new layer and assgin a license key.
clientId | String<!– System.String –> | The clientId for the WorldMapKit Server. |
privateKey | String<!– System.String –> | The privateKey for the WorldMapKit Server. |
Return Type | Description |
Void<!– System.Void –> |
<!– ThinkGeo.MapSuite.PortableCore.WorldMapKitLayer –> Go Back
Layer<!– ThinkGeo.MapSuite.PortableCore.Layer –> | A cloned Layer. |
<!– ThinkGeo.MapSuite.PortableCore.Layer –> Go Back
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter is the canvas object or a GeoImage to draw on. |
labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | This parameter represents the labels used for collision detection and duplication checking. |
RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | This method returns the bounding box of the Layer. |
Int32<!– System.Int32 –> |
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | The request URLs from the client to the WMS servers. |
worldExtent | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | The world extent requested by the client to get the map. |
canvasWidth | Int32<!– System.Int32 –> | The returning map width, as well as the drawing canvas width. |
canvasHeight | Int32<!– System.Int32 –> | The returning map height, as well as the drawing canvas height. |
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | The exception format at the server side. |
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns the names of all layers at the server side. |
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns the output format at the server side. |
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns the names of all styles at the server side. |
String<!– System.String –> | Returns a string reflecting the version of the service in WMS. |
Type<!– System.Type –> |
extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> |
extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –> |
bufferTime | TimeSpan<!– System.TimeSpan –> |
extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –> | |
extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | |
<!– ThinkGeo.MapSuite.PortableCore.Layer(overriden) –> Go Back
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | |
attribution | String<!– System.String –> |
When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | The target canvas to draw the layer. |
e | Exception<!– System.Exception –> | The exception thrown when layer.Draw(). |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter is the canvas object or a GeoImage to draw on. This parameter represents the labels used for collision detection and duplication checking. |
labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | This parameter is the labels in all layers. |
ThreadSafetyLevel<!– ThinkGeo.MapSuite.PortableCore.ThreadSafetyLevel –> |
<!– static –> This method retures a value represents whether the currentExtent is within the passing in thresholds.
Boolean<!– System.Boolean –> | This method retures a value represents whether the currentExtent is within the passing in thresholds. If returns true, is within. otherwise out of thresholds. |
currentExtent | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | The RectangleShape represents the current extent. |
upperThreshold | Double<!– System.Double –> | The upper threshold for scale. |
lowerThreshold | Double<!– System.Double –> | The lower threshold for scale. |
canvasWidth | Int32<!– System.Int32 –> | The width of canvas which will use to draw. |
mapUnit | GeographyUnit<!– ThinkGeo.MapSuite.PortableCore.GeographyUnit –> | The GeographyUnit represents map unit for currentExtent |
dpi | Single<!– System.Single –> | This parameter is the dpi of the current extent. |
args | DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingAttributionLayerEventArgs –> |
e | DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionLayerEventArgs –> |
e | DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingProgressChangedEventArgs –> |
args | DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnAttributionLayerEventArgs –> |
e | DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnExceptionLayerEventArgs –> |
eventArgs | RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestedDrawingLayerEventArgs –> |
eventArgs | RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestingDrawingLayerEventArgs –> |
e | SendingWebRequestEventArgs<!– ThinkGeo.MapSuite.PortableCore.SendingWebRequestEventArgs –> |
e | SentWebRequestEventArgs<!– ThinkGeo.MapSuite.PortableCore.SentWebRequestEventArgs –> |
This abstract method is called from the concrete public method Open. The open method plays an important role, as it is responsible for initializing the Layer. Most methods on the Layer will throw an exception if the state of the Layer is not opened. When the map draws each layer, the layer will be opened as one of its first steps; then, after it is finished drawing with that layer, it will close it. In this way, we are sure to release all resources used by the Layer.
Return Type |
Return Type |
Return Type |
DrawingExceptionMode<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionMode –> |
Return Type |
The value of WorldMapKitLayer is false.
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
WorldMapKitLayerType<!– ThinkGeo.MapSuite.PortableCore.WorldMapKitLayerType –> |
Is the current scale is less than this value, the map will not render.
Return Type |
Return Type |
Return Type |
Return Type |
WorldMapKitProjection<!– ThinkGeo.MapSuite.PortableCore.WorldMapKitProjection –> |
Return Type |
GeoWebProxy<!– ThinkGeo.MapSuite.PortableCore.GeoWebProxy –> |
Return Type |
Return Type |
BitmapTileCache<!– ThinkGeo.MapSuite.PortableCore.BitmapTileCache –> |
Return Type |
Return Type |
Is the current scale is beyond this value, the map will not render.
Return Type |
Return Type |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
