<!– Structure –> This structure represents the TileMatrixCell which will be used in the TileMatrix system.
*System.ValueType **ThinkGeo.MapSuite.PortableCore.TileMatrixCell
![]() | Int64, Int64, RectangleShape | This is the constructor used to create a TileMatrixCell. |
![]() | Object | Object(overriden) | This method is an override of the Equals functionality. |
![]() | Object(overriden) | This method is an override of the GetHashCode functionality. | |
![]() | Object | ||
![]() | Object(overriden) | This method is an override of the ToString functionality. |
![]() | Object | ||
![]() | Object |
![]() | RectangleShape | This property gets or sets the BoundingBox of the stucture. | |
![]() | Int64 | This property gets or sets the Column number of the stucture. | |
![]() | Int64 | This property gets or sets the Row number of the stucture. |
Name | Type | Description |
row | Int64<!– System.Int64 –> | This parameter represents the row number of the TileMatrixCell. |
column | Int64<!– System.Int64 –> | This parameter represents the column number of the TileMatrixCell. |
boundingBox | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | This parameter represents the boundingBox of the TileMatrixCell. |
Return Type | Description |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
String<!– System.String –> |
Void<!– System.Void –> |
Return Type |
<!– ThinkGeo.MapSuite.PortableCore.TileMatrixCell –> Go Back
Return Type |
Return Type |
