<!– Class –>
*System.Object ThinkGeo.MapSuite.PortableCore.CogoCall *ThinkGeo.MapSuite.PortableCore.TangentCurveCogoCall
TangentCurveCogoCall | |||
TangentCurveCogoCall | CogoCurveParameterType, Double, CogoCurveParameterType, Double, CogoCurveDirection |
GetCallLine | PointShape, PointShape | CogoCall | |
GetDescriptionString | CogoDirectionType, AngleUnit | CogoCall | This method is the concrete method which always calls the associated core method. This is used to give us, the framework designer, flexability when user override the core method. |
GetTraverseString | CogoDirectionType, AngleUnit | CogoCall | This method is the concrete method which always calls the associated core method. This is used to give us, the framework designer, flexability when user override the core method. |
LoadFromTraverseString | String, CogoDirectionType, AngleUnit | CogoCall | This method is the concrete method which always calls the associated core method. This is used to give us, the framework designer, flexability when user override the core method. |
GetCallLineCore | PointShape, PointShape | CogoCall(overriden) | |
GetDescriptionStringCore | CogoDirectionType, AngleUnit | CogoCall(overriden) | |
GetTraverseStringCore | CogoDirectionType, AngleUnit | CogoCall(overriden) | |
LoadFromTraverseStringCore | String, CogoDirectionType, AngleUnit | CogoCall(overriden) | |
CurveDirection | CogoCurveDirection | ||
FirstParameter | Double | ||
FirstParameterType | CogoCurveParameterType | ||
IsPointOfBeginning | Boolean | CogoCall | This porperty denotes if this call is the point of begining. This is the point from which we will begin the polygon |
SecondParameter | Double | ||
SecondParameterType | CogoCurveParameterType |
| firstParameterType | CogoCurveParameterType<!– ThinkGeo.MapSuite.PortableCore.CogoCurveParameterType –> | |
| firstParameter | Double<!– System.Double –> | |
| secondParameterType | CogoCurveParameterType<!– ThinkGeo.MapSuite.PortableCore.CogoCurveParameterType –> | |
| secondParameter | Double<!– System.Double –> | |
| curveDirection | CogoCurveDirection<!– ThinkGeo.MapSuite.PortableCore.CogoCurveDirection –> |
| LineShape<!– ThinkGeo.MapSuite.PortableCore.LineShape –> |
| startPoint | PointShape<!– ThinkGeo.MapSuite.PortableCore.PointShape –> | |
| backsightPoint | PointShape<!– ThinkGeo.MapSuite.PortableCore.PointShape –> |
<!– ThinkGeo.MapSuite.PortableCore.CogoCall –> Go Back
| returningDirectionType | CogoDirectionType<!– ThinkGeo.MapSuite.PortableCore.CogoDirectionType –> | |
| returningAngleUnit | AngleUnit<!– ThinkGeo.MapSuite.PortableCore.AngleUnit –> |
| traverseString | String<!– System.String –> | |
| directionType | CogoDirectionType<!– ThinkGeo.MapSuite.PortableCore.CogoDirectionType –> | |
| angleUnit | AngleUnit<!– ThinkGeo.MapSuite.PortableCore.AngleUnit –> |
<!– ThinkGeo.MapSuite.PortableCore.CogoCall(overriden) –> Go Back
<!– ThinkGeo.MapSuite.PortableCore.TangentCurveCogoCall –> Go Back
