thinkgeo.mapsuite.portablecore.simplecandidate
ThinkGeo.MapSuite.PortableCore.SimpleCandidate
<!– Class –> This class stores simple label information used in the PositionStyle.
This class is used in the PositionStyle for storing simple label infromation. It has a limited scope.
Public MethodSimpleCandidate This is a constructor for the class.
Public MethodSimpleCandidate String, PolygonShape This is a constructor for the class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyOriginalText String This property gets and sets the text for the label.
Public PropertySimplePolygonInScreenCoordinate PolygonShape This property gets and sets the polygon in screen coordinates that represents the area of the label.
SimpleCandidate()
Overloads
This is the default constructor. If you use this constructor, then you need to manually set the properties necessary for this class.
Name Type Description
Go Back
SimpleCandidate(String, PolygonShape)
Overloads
This constructor allows you to pass in the original text and the simple polygon in screen coordinates.
originalText String<!– System.String –> This parameter is the text for the label.
simplePolygonInScreenCoordinate PolygonShape<!– ThinkGeo.MapSuite.PortableCore.PolygonShape –> This parameter is a polygon in screen coordinates that represents the area of the label.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
Void<!– System.Void –>
OriginalText
Return Type
<!– ThinkGeo.MapSuite.PortableCore.SimpleCandidate –> Go Back
Return Type
thinkgeo.mapsuite.portablecore.simplecandidate.1440040133.txt.gz · Last modified: 2015/09/21 08:18 (external edit)
