thinkgeo.mapsuite.portablecore.screenpointf
ThinkGeo.MapSuite.Core.ScreenPointF
    • System.ValueType
      • ThinkGeo.MapSuite.Core.ScreenPointF
ScreenPointF(Single,Single)
This constructor allows you to create a screen point by passing in an X & Y.
  • x
    • Type:Single
    • Description:This parameter represents the horizontal value of a screen point.
  • y
    • Type:Single
    • Description:This parameter represents the vertical value of a screen point.
This method is an override of the Equals functionality.
  • Description:This method returns the Equals functionality.
    • Description:This parameter is the object you want to check to see if it is equal to the current instance.
This method is an override of the GetHashCode functionality.
  • Description:This method returns the hash code.
X
This property returns the X, or horizontal, value of the screen point.
  • Type:Single
Y
This property returns the Y, or vertical, value of the screen point.
  • Type:Single
thinkgeo.mapsuite.portablecore.screenpointf.1442823489.txt.gz · Last modified: 2015/09/21 08:18 by admin
