<!– Structure –> This structure represents a single point in screen coordinates.
*System.ValueType **ThinkGeo.MapSuite.PortableCore.ScreenPointF
![]() | Single, Single | This constructor allows you to create a screen point by passing in an X & Y. |
![]() | Object | Object(overriden) | This method is an override of the Equals functionality. |
![]() | Object(overriden) | This method is an override of the GetHashCode functionality. | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
Name | Type | Description |
x | Single<!– System.Single –> | This parameter represents the horizontal value of a screen point. |
y | Single<!– System.Single –> | This parameter represents the vertical value of a screen point. |
Return Type | Description |
Boolean<!– System.Boolean –> | This method returns the Equals functionality. |
obj | Object<!– System.Object –> | This parameter is the object you want to check to see if it is equal to the current instance. |
Int32<!– System.Int32 –> | This method returns the hash code. |
Type<!– System.Type –> |
String<!– System.String –> |
Void<!– System.Void –> |
This property returns the X, or horizontal, value of the screen point.
Return Type |
<!– ThinkGeo.MapSuite.PortableCore.ScreenPointF –> Go Back
This property returns the Y, or vertical, value of the screen point.
Return Type |
