<!– Structure –> This structure is used to describe a range of tiles for a given extent. Basiclly, 4 values exists : the Row range is from MinColumnIndex to MaxColumnIndex, the Column range is from the MinRowIndex to MaxRowIndex.
*System.ValueType **ThinkGeo.MapSuite.PortableCore.RowColumnRange
![]() | Int64, Int64, Int64, Int64 | Contructor of the structure to instance a RowColumnRange. |
![]() | Object | Object(overriden) | This method is an override of the Equals functionality. |
![]() | Object(overriden) | This method is an override of the GetHashCode functionality. | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Int64 | Gets or sets the Max Column Index which stands for the right boundary. | |
![]() | Int64 | Gets or sets the Max Row Index which stands for the lower boundary. | |
![]() | Int64 | Gets or sets the Min Column Index which stands for the left boundary. | |
![]() | Int64 | Gets or sets the Min Row Index which stands for the up boundary. |
Name | Type | Description |
minRowIndex | Int64<!– System.Int64 –> | Min Row Index which stands for the up boundary. |
maxRowIndex | Int64<!– System.Int64 –> | Max Row Index which stands for the lower boundary. |
minColumnIndex | Int64<!– System.Int64 –> | Min Column Index which stands for the left boundary. |
maxColumnIndex | Int64<!– System.Int64 –> | Max Column Index which stands for the right boundary. |
Return Type | Description |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
String<!– System.String –> |
Void<!– System.Void –> |
Return Type |
<!– ThinkGeo.MapSuite.PortableCore.RowColumnRange –> Go Back
Return Type |
Return Type |
Return Type |
