thinkgeo.mapsuite.portablecore.rebuildingshapefilefeaturesourceeventargs
ThinkGeo.MapSuite.PortableCore.RebuildingShapeFileFeatureSourceEventArgs
<!– Class –> This class represents the parameters passed in through the BuildingIndex event in ShapeFileFeatureSource class.
Public MethodRebuildingShapeFileFeatureSourceEventArgs This is the default constructor of the event args.
Public MethodRebuildingShapeFileFeatureSourceEventArgs Int32, Int32, Feature, DateTime, Boolean This is the constructor of the event args by passing the desired parameters.
Public MethodRebuildingShapeFileFeatureSourceEventArgs Int32, Int32, Feature, DateTime, Boolean, String
Public MethodGetType Object
Public MethodToString Object
Public PropertyCancel Boolean Gets or sets to see if we need to cancel the building index of current record.
Public PropertyCurrentFeature Feature Gets the current feature for building rTree index.
Public PropertyCurrentRecordIndex Int32 Gets the current record index for building rTree index.
Public PropertyRecordCount Int32 Gets the total record count to build rTree index.
Public PropertyShapePathFilename String
Public PropertyStartProcessTime DateTime Gets the starting process time for building the index.
RebuildingShapeFileFeatureSourceEventArgs()
If you use this constructor, you have to set the properties manually.
Name Type Description
Go Back
RebuildingShapeFileFeatureSourceEventArgs(Int32, Int32, Feature, DateTime, Boolean)
recordCount Int32<!– System.Int32 –>
currentRecordIndex Int32<!– System.Int32 –>
currentFeature Feature<!– ThinkGeo.MapSuite.PortableCore.Feature –>
startProcessTime DateTime<!– System.DateTime –>
cancel Boolean<!– System.Boolean –>
Go Back
RebuildingShapeFileFeatureSourceEventArgs(Int32, Int32, Feature, DateTime, Boolean, String)
shapePathFilename String<!– System.String –>
Go Back
Return Type Description
Type<!– System.Type –>
Void<!– System.Void –>
Cancel
Return Type
<!– ThinkGeo.MapSuite.PortableCore.RebuildingShapeFileFeatureSourceEventArgs –> Go Back
CurrentFeature
Return Type
CurrentRecordIndex
Return Type
RecordCount
Return Type
ShapePathFilename
Return Type
StartProcessTime
Return Type
thinkgeo.mapsuite.portablecore.rebuildingshapefilefeaturesourceeventargs.1440040133.txt.gz · Last modified: 2015/09/21 08:16 (external edit)
