<!– Class –> This class provides commonly-used GeoPointStyles and some methods to create various kinds of GeoPointstyles. A GeoStyle is a kind of sheet used to render the map.
The <strong>GeoStyle</strong> is a very important concept. MapSuite provides three kinds of styles: <strong>GeoAreaStyle</strong>, <strong>GeoLineStyle</strong>, and <strong>GeoPointStyle</strong>. <strong>GeoAreaStyle</strong> is used to render area-type data on the map, <strong>GeoLineStyle</strong> is used to render line-type data on the map, <strong>GeoPointStyle</strong> is used to render point-type data on the map.
*System.Object **ThinkGeo.MapSuite.PortableCore.PointStyles
![]() ![]() | GeoColor, Single, GeoColor, Single, GeoColor, Single, GeoColor, Single | Static API to create a compound circle point style. | |
![]() ![]() | GeoColor, Single, GeoColor, Single, GeoColor, Single | Static API to create a compound circle point style. | |
![]() ![]() | PointSymbolType, GeoColor, GeoColor, Single, Single, PointSymbolType, GeoColor, GeoColor, Single, Single | Static API to create a compound circle point style. | |
![]() ![]() | GeoColor, Single | Static API to create a circle point style. | |
![]() ![]() | GeoColor, Single, GeoColor, Single | Static API to create a circle point style. | |
![]() ![]() | GeoColor, Single, GeoColor | Static API to create a circle point style. | |
![]() ![]() | PointSymbolType, GeoColor, Single | Static API to create a point style. | |
![]() ![]() | PointSymbolType, GeoColor, GeoColor, Single, Single | Static API to create a point style. | |
![]() ![]() | PointSymbolType, GeoColor, GeoColor, Single | Static API to create a point style. | |
![]() ![]() | GeoColor, Single | Static API to create a square point style. | |
![]() ![]() | GeoColor, Single, GeoColor | Static API to create a square point style. | |
![]() ![]() | GeoColor, Single, GeoColor, Single | Static API to create a square point style. | |
![]() ![]() | GeoColor, Single, GeoColor, Single | Static API to create a star point style. | |
![]() ![]() | GeoColor, Single, GeoColor | Static API to create a star point style. | |
![]() ![]() | GeoColor, Single | Static API to create a star point style. | |
![]() ![]() | GeoColor, Single, GeoColor | Static API to create a triangle point style. | |
![]() ![]() | GeoColor, Single, GeoColor, Single | Static API to create a triangle point style. | |
![]() ![]() | GeoColor, Single | Static API to create a triangle point style. | |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Object | ||
![]() | Object |
![]() ![]() | PointStyle | Get the commonly-used PointStyle to render a capital. | |
![]() ![]() | PointStyle | Get the commonly-used PointStyle to render a city. | |
<!– static –> Static API to create a compound circle point style.
Return Type | Description |
PointStyle<!– ThinkGeo.MapSuite.PortableCore.PointStyle –> | The created point style. |
Name | Type | Description |
fillColor1 | GeoColor<!– ThinkGeo.MapSuite.PortableCore.GeoColor –> | This parameter determines the outer circle's PointStyle fill color. |
size1 | Single<!– System.Single –> | This parameter determines the outer circle's PointStyle size. |
outlineColor1 | GeoColor<!– ThinkGeo.MapSuite.PortableCore.GeoColor –> | This parameter determines the outer circle's PointStyle outline color. |
outlineWidth1 | Single<!– System.Single –> | This parameter determines the outer circle's PointStyle outline width. |
fillColor2 | GeoColor<!– ThinkGeo.MapSuite.PortableCore.GeoColor –> | This parameter determines the inner circle's PointStyle fill color. |
size2 | Single<!– System.Single –> | This parameter determines the inner circle's PointStyle size. |
outlineColor2 | GeoColor<!– ThinkGeo.MapSuite.PortableCore.GeoColor –> | This parameter determines the inner circle's PointStyle outline color. |
outlineWidth2 | Single<!– System.Single –> | This parameter determines the inner circle's PointStyle outline width. |
<!– ThinkGeo.MapSuite.PortableCore.PointStyles –> Go Back
pointStyle1 | PointSymbolType<!– ThinkGeo.MapSuite.PortableCore.PointSymbolType –> | This parameter determines the outer circle's pointstyle symbol type. |
pointStyle2 | PointSymbolType<!– ThinkGeo.MapSuite.PortableCore.PointSymbolType –> | This parameter determines the inner circle's pointstyle symbol type. |
size2 | Single<!– System.Single –> | This parameter determines the inner circle PointStyle size. |
<!– static –> Static API to create a circle point style.
fillColor | GeoColor<!– ThinkGeo.MapSuite.PortableCore.GeoColor –> | This parameter determines the PointStyle fill color. |
size | Single<!– System.Single –> | This parameter determines the PointStyle size. |
outlineColor | GeoColor<!– ThinkGeo.MapSuite.PortableCore.GeoColor –> | This parameter determines the PointStyle outline color. |
outlineWidth | Single<!– System.Single –> | This parameter determines the PointStyle outline width. |
<!– static –> Static API to create a point style.
pointStyle | PointSymbolType<!– ThinkGeo.MapSuite.PortableCore.PointSymbolType –> | This parameter determines the PointStyle symbol type. |
<!– static –> Static API to create a square point style.
<!– static –> Static API to create a star point style.
<!– static –> Static API to create a triangle point style.
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
String<!– System.String –> |
Void<!– System.Void –> |
<!– static –> Get the commonly-used PointStyle to render a capital.
Return Type |
Return Type |
Return Type |
<!– static –> Get the commonly-used PointStyle to render a city.
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
