thinkgeo.mapsuite.portablecore.openstreetmaplayer
ThinkGeo.MapSuite.Core.OpenStreetMapLayer
This class is use for Open Street Map Layer, and you also can get map from open street map server.
      • ThinkGeo.MapSuite.Core.OpenStreetMapLayer
OpenStreetMapLayer()
The default constructor
The constructor initilizes the properties. WebProxy is set to null.
OpenStreetMapLayer(WebProxy)
This is the constructor the for the class.
This constructor initializes a new layer and assgin a web proxy.
  • webProxy
    • Type:WebProxy
    • Description:The web proxy for OpenStreetMap Server
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
GetThreadSafetyLevel()
CloneDeep()
  • Type:Layer
Open()
Close()
GetBoundingBox()
OpenCore()
  • Description:None
CloseCore()
This method closes the Layer and releases any resources it was using.
This abstract method is called from the concrete public method Close. The close method plays an important role in the life cycle of the Layer. It may be called after drawing to release any memory and other resources that were allocated since the Open method was called. If you override this method, it is recommended that you take the following things into account: This method may be called multiple times, so we suggest you write the method so that that a call to a closed Layer is ignored and does not generate an error. We also suggest that in the Close you free all resources that have been opened. Remember that the object will not be destroyed, but will be re-opened possibly in the near future.
  • Description:None
This method draws the Layer.
This method is the concrete wrapper for the abstract method DrawCore. This method draws the representation of the layer based on the extent you provided. When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
  • Description:None
  • canvas
    • Type:GeoCanvas
    • Description:This parameter is the canvas object or a GeoImage to draw on.
  • labelsInAllLayers
    • Description:This parameter represents the labels used for collision detection and duplication checking.
SendWebRequest(WebRequest)
  • Type:WebResponse
  • webRequest
    • Type:WebRequest
SendWebRequestCore(WebRequest)
  • Type:WebResponse
  • webRequest
    • Type:WebRequest
OnSendingWebRequest(SendingWebRequestEventArgs)
OnSentWebRequest(SentWebRequestEventArgs)
GetThreadSafetyLevelCore()
CloneDeepCore()
  • Type:Layer
GetBoundingBoxCore()
  • e
    • Type:Exception
  • e
    • Type:Exception
  • attribution
CachePictureFormat
The cache for picture format
get or set a OpenStreetMapLayerPictureFormat object
TimeoutInSeconds
Gets or sets a value represents the request timeout from the OpenStreetMap server.
TileCache
ProjectedTileCache
WebProxy
This property gets or sets the proxy used for requesting a Web Response.
  • Type:WebProxy
CustomServerUris
  • Type:Collection<Uri>
ProjectionFromSphericalMercator
ZoomlevelSet
RequestDrawingInterval
  • Type:TimeSpan
IsOpen
HasBoundingBox
DrawingTime
  • Type:TimeSpan
Attribution
IsVisible
Transparency
  • Type:Single
BlueTranslation
  • Type:Single
RedTranslation
  • Type:Single
GreenTranslation
  • Type:Single
KeyColors
IsNegative
IsGrayscale
DrawingExceptionMode
IsOpenCore
SendingWebRequest N/A
Event Arguments:SendingWebRequestEventArgs
SentWebRequest N/A
Event Arguments:SentWebRequestEventArgs
RequestedDrawing N/A
RequestingDrawing N/A
DrawingProgressChanged N/A
DrawingException N/A
DrawnException N/A
DrawingAttribution N/A
DrawnAttribution N/A
thinkgeo.mapsuite.portablecore.openstreetmaplayer.1442823317.txt.gz · Last modified: 2015/09/21 08:15 by admin
