<!– Class –>
*System.Object ThinkGeo.MapSuite.PortableCore.Style *ThinkGeo.MapSuite.PortableCore.NoaaWeatherStationStyle
![]() | Style | Create a copy of style using the deep clone process. | |
![]() | IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style | This method draws the features on the canvas you provided. |
![]() | IEnumerable<BaseShape>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style | This method draws the shapes on the canvas you provided. |
![]() | GeoCanvas, DrawingRectangleF | Style | This method draws a sample feature on the canvas you provided. |
![]() | GeoCanvas | Style | |
![]() | Object | Object | |
![]() | Object | ||
![]() | Style | This method returns the column data for each feature that is required for the style to properly draw. | |
![]() | Object | ||
![]() | Object |
![]() | Style | Create a copy of style using the deep clone process. The default implementation method uses serialization. | |
![]() | IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style(overriden) | |
![]() | GeoCanvas, DrawingRectangleF | Style(overriden) | |
![]() | Object | ||
![]() | Style(overriden) | ||
![]() | Object |
![]() | Collection<String> | Style | |
![]() | Boolean | Style | This property gets and sets the active status of the style. |
![]() | String | Style | This property gets and set the name of the style. |
![]() | Collection<String> | Style | This property gets the collection of fields that are required for the style. |
Name | Type | Description |
Return Type | Description |
Style<!– ThinkGeo.MapSuite.PortableCore.Style –> | A cloned style. |
<!– ThinkGeo.MapSuite.PortableCore.Style –> Go Back
Void<!– System.Void –> |
features | IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.Feature} –> | This parameter represents the features you want to draw on the canvas. |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter represents the canvas you want to draw the features on. |
labelsInThisLayer | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | The labels will be drawn in the current layer only. |
labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | The labels will be drawn in all layers. |
shapes | IEnumerable<BaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.BaseShape} –> | This parameter represents the shapes you want to draw on the canvas. |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter represents the canvas you want to draw the shapes on. |
This method is the concrete wrapper for the abstract method DrawSampleCore. In this method we draw a sample style on the canvas you provided. This is typically used to display a legend or other sample area.
drawingExtent | DrawingRectangleF<!– ThinkGeo.MapSuite.PortableCore.DrawingRectangleF –> |
Int32<!– System.Int32 –> |
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns a collection of column names that the style needs. |
Type<!– System.Type –> |
String<!– System.String –> |
features | IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.Feature} –> | |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | |
labelsInThisLayer | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | |
<!– ThinkGeo.MapSuite.PortableCore.Style(overriden) –> Go Back
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
