<!– Class –> This class represents the location of a piece of a label that may be drawn.
This class is used within the labeling logic, specifically in the labeling candidate. The object may represent an entire label or, in the case of a label spline, a single character in the label.
*System.Object **ThinkGeo.MapSuite.PortableCore.LabelInformation
![]() | This is the constructor for the class. | ||
![]() | PointShape, String, Double | This is the constructor for the class. |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Object | ||
![]() | Object |
![]() | PointShape | This property gets and sets the position of a piece of a label, in screen coordinates. | |
![]() | Double | This property gets and sets the angle of rotation for the label. | |
![]() | String | This property gets and sets the text of the label. |
If you use this constructor, you should set the various properties manually.
Name | Type | Description |
This constructor allows you to set all of the class properties.
positionInScreenCoordinates | PointShape<!– ThinkGeo.MapSuite.PortableCore.PointShape –> | This parameter is the position of the label that may draw. |
text | String<!– System.String –> | This parameter is the text for the label. |
rotationAngle | Double<!– System.Double –> | This parameter is the angle of rotation for the label. |
Return Type | Description |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
Void<!– System.Void –> |
Return Type |
<!– ThinkGeo.MapSuite.PortableCore.LabelInformation –> Go Back
This could be the rotation of the entire label text, a single character, or a set of characters.
Return Type |
This may be the entire label text or a single character.
Return Type |
