<!– Class –>
*System.Object ThinkGeo.MapSuite.PortableCore.Layer *ThinkGeo.MapSuite.PortableCore.IsoLineLayer ThinkGeo.MapSuite.PortableCore.DynamicIsoLineLayer ThinkGeo.MapSuite.PortableCore.GridIsoLineLayer ThinkGeo.MapSuite.PortableCore.InMemoryGridIsoLineLayer
IsoLineLayer | |||
IsoLineLayer | IEnumerable<Double> | ||
IsoLineLayer | IEnumerable<Double>, Double, Double | ||
IsoLineLayer | IEnumerable<Double>, Double, Double, IsoLineType |
| Name | Parameters | DeclaringType | Summary | |
CloneDeep | Layer | Create a copy of Layer using the deep clone process. | ||
Close | Layer | This method closes the Layer and releases any resources it was using. | ||
Draw | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. | |
Equals | Object | Object | ||
GetBoundingBox | Layer | This method returns the bounding box of the Layer. | ||
GetHashCode | Object | |||
![]() GetIsoFeatures(GridCell[,, IEnumerable<Double>, String, IsoLineType, Double) | GetIsoFeatures]] | GridCell[, ], IEnumerable<Double>, String, IsoLineType, Double | ||
![]() GetIsoFeatures(GridCell[,, IEnumerable<Double>, String, IsoLineType) | GetIsoFeatures]] | GridCell[, ], IEnumerable<Double>, String, IsoLineType | ||
![]() GetIsoFeatures | GridFeatureSource, IEnumerable<Double>, String, IsoLineType | |||
![]() GetIsoLineLevels(GridCell[,, Int32) | GetIsoLineLevels]] | GridCell[, ], Int32 | ||
![]() GetIsoLineLevels | IEnumerable<Double>, Int32 | |||
![]() GetIsoLineLevels | Dictionary<PointShape, Double>, Int32 | |||
GetType | Object | |||
Open | Layer | This method opens the Layer so that it is initialized and ready to use. | ||
RequestDrawing | Layer | |||
RequestDrawing | RectangleShape | Layer | ||
RequestDrawing | IEnumerable<RectangleShape> | Layer | ||
RequestDrawing | TimeSpan | Layer | ||
RequestDrawing | RectangleShape, TimeSpan | Layer | ||
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan | Layer | ||
CloseCore | Layer | This method closes the Layer and releases any resources it was using. | |
DrawCore | GeoCanvas, Collection<SimpleCandidate> | Layer(overriden) | |
DrawExceptionCore | GeoCanvas, Exception | Layer | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
GetBoundingBoxCore | Layer | This method returns the bounding box of the Layer. | |
GetFeaturesForDrawingCore | GeoCanvas, Collection<SimpleCandidate> | ||
MemberwiseClone | Object | ||
OpenCore | Layer(overriden) |
CustomStyles | Collection<Style> | ||
DataValueColumnName | String | ||
HasBoundingBox | Boolean | Layer | This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. |
IsoLineLevels | Collection<Double> | ||
IsoLineType | IsoLineType | ||
LowerScale | Double | ||
NoDataValue | Double | ||
UpperScale | Double |
IsOpenCore | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
| isoLineLevels | IEnumerable<Double><!– System.Collections.Generic.IEnumerable{System.Double} –> |
| isoLineLevels | IEnumerable<Double><!– System.Collections.Generic.IEnumerable{System.Double} –> | |
| lowerScale | Double<!– System.Double –> | |
| upperScale | Double<!– System.Double –> |
| upperScale | Double<!– System.Double –> | |
| isoLineType | IsoLineType<!– ThinkGeo.MapSuite.PortableCore.IsoLineType –> |
| Layer<!– ThinkGeo.MapSuite.PortableCore.Layer –> | A cloned Layer. |
<!– ThinkGeo.MapSuite.PortableCore.Layer –> Go Back
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter is the canvas object or a GeoImage to draw on. |
| labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | This parameter represents the labels used for collision detection and duplication checking. |
| RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | This method returns the bounding box of the Layer. |
<!– static –>
| Collection<Feature><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.Feature} –> |
| gridMatrix | GridCell[,]<!– ThinkGeo.MapSuite.PortableCore.GridCell, –> | |
| dataValueColumnName | String<!– System.String –> | |
| isoLineType | IsoLineType<!– ThinkGeo.MapSuite.PortableCore.IsoLineType –> | |
| noDataValue | Double<!– System.Double –> |
<!– ThinkGeo.MapSuite.PortableCore.IsoLineLayer –> Go Back
<!– static –>
<!– static –>
| gridFeatureSource | GridFeatureSource<!– ThinkGeo.MapSuite.PortableCore.GridFeatureSource –> | |
<!– static –>
| Collection<Double><!– System.Collections.ObjectModel.Collection{System.Double} –> |
| isoLineLevelCount | Int32<!– System.Int32 –> |
<!– static –>
| dataValues | IEnumerable<Double><!– System.Collections.Generic.IEnumerable{System.Double} –> | |
<!– static –>
| dataPoints | Dictionary<PointShape,Double><!– System.Collections.Generic.Dictionary{ThinkGeo.MapSuite.PortableCore.PointShape,System.Double} –> | |
| extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> |
| extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –> |
| bufferTime | TimeSpan<!– System.TimeSpan –> |
| extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | |
| extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –> | |
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | |
<!– ThinkGeo.MapSuite.PortableCore.Layer(overriden) –> Go Back
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | The target canvas to draw the layer. |
| args | DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingAttributionLayerEventArgs –> |
| e | DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionLayerEventArgs –> |
| e | DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingProgressChangedEventArgs –> |
| args | DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnAttributionLayerEventArgs –> |
| e | DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnExceptionLayerEventArgs –> |
| eventArgs | RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestedDrawingLayerEventArgs –> |
| eventArgs | RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestingDrawingLayerEventArgs –> |
| Collection<Style><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.Style} –> |
| DrawingExceptionMode<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionMode –> |
The default value is false.
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
