<!– Class –> HeatStyle allows you to better visualize data by making areas of high concentration “hotter” using warmer colors and low density areas visually cooler.
![]() | This is the default constructor of the class. | ||
![]() | Int32 | This is a constructor for the class. | |
![]() | Int32, Int32 | This is a constructor for the class. | |
![]() | Int32, Double, DistanceUnit | This is a constructor for the class. | |
![]() | Int32, Int32, Double, DistanceUnit | This is a constructor for the class. | |
![]() | String, Double, Double | This is a constructor for the class. | |
![]() | Int32, String, Double, Double | This is a constructor for the class. | |
![]() | String, Double, Double, Double, DistanceUnit | This is a constructor for the class. | |
![]() | Int32, String, Double, Double, Double, DistanceUnit | This is a constructor for the class. | |
![]() | Int32, Int32, String, Double, Double, Double, DistanceUnit | This is a constructor for the class. |
![]() | Style | Create a copy of style using the deep clone process. | |
![]() | IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style | This method draws the features on the canvas you provided. |
![]() | IEnumerable<BaseShape>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style | This method draws the shapes on the canvas you provided. |
![]() | GeoCanvas, DrawingRectangleF | Style | This method draws a sample feature on the canvas you provided. |
![]() | GeoCanvas | Style | |
![]() | Object | Object | |
![]() | Object | ||
![]() | Style | This method returns the column data for each feature that is required for the style to properly draw. | |
![]() | Object | ||
![]() | Object |
![]() | Style | Create a copy of style using the deep clone process. The default implementation method uses serialization. | |
![]() | IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style(overriden) | This method draws the features on the canvas you provided. |
![]() | Object | ||
![]() | Style(overriden) | This method returns the column data for each feature that is required for the style to properly draw. | |
![]() | Object |
![]() | Int32 | ||
![]() | Collection<GeoColor> | ||
![]() | Collection<String> | Style | |
![]() | String | ||
![]() | Double | ||
![]() | Double | ||
![]() | Boolean | Style | This property gets and sets the active status of the style. |
![]() | String | Style | This property gets and set the name of the style. |
![]() | Int32 | ||
![]() | Double | ||
![]() | DistanceUnit | ||
![]() | Collection<String> | Style | This property gets the collection of fields that are required for the style. |
Name | Type | Description |
pointIntensity | Int32<!– System.Int32 –> | The parameter represents the point intensity, the default value is 10. |
alpha | Int32<!– System.Int32 –> | The parameter represents the alpha value of color, the default value is 255. |
pointRadius | Double<!– System.Double –> | The parameter represents the point radius, the default value is 50 kilometers. |
pointRadiusUnit | DistanceUnit<!– ThinkGeo.MapSuite.PortableCore.DistanceUnit –> | The parameter represents the unit of point radius, the default value is kilometer. |
intensityColumnName | String<!– System.String –> | The parameter represents the intensity column name, the default value is empty string. |
intensityRangeStart | Double<!– System.Double –> | The parameter represents the range start of intensity, the default value is 0. |
intensityRangeEnd | Double<!– System.Double –> | The parameter represents the range end of intensity, the default value is 0. |
Return Type | Description |
Style<!– ThinkGeo.MapSuite.PortableCore.Style –> | A cloned style. |
<!– ThinkGeo.MapSuite.PortableCore.Style –> Go Back
Void<!– System.Void –> |
features | IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.Feature} –> | This parameter represents the features you want to draw on the canvas. |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter represents the canvas you want to draw the features on. |
labelsInThisLayer | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | The labels will be drawn in the current layer only. |
labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | The labels will be drawn in all layers. |
shapes | IEnumerable<BaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.BaseShape} –> | This parameter represents the shapes you want to draw on the canvas. |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter represents the canvas you want to draw the shapes on. |
This method is the concrete wrapper for the abstract method DrawSampleCore. In this method we draw a sample style on the canvas you provided. This is typically used to display a legend or other sample area.
drawingExtent | DrawingRectangleF<!– ThinkGeo.MapSuite.PortableCore.DrawingRectangleF –> |
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns a collection of column names that the style needs. |
Type<!– System.Type –> |
This abstract method is called from the concrete public method Draw. In this method, we take the features you passed in and draw them on the canvas you provided. Each style (based on its properties) may draw each feature differently.
When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
<!– ThinkGeo.MapSuite.PortableCore.Style(overriden) –> Go Back
This virtual method is called from the concrete public method Draw. In this method, we draw a sample style on the canvas you provided. This is typically used to display a legend or other sample area.
When implementing this virtual method, consider the canvas size and draw the sample image appropriately. You should keep in mind that the sample typically shows up on a legend.
This abstract method is called from the concrete public method GetRequiredFieldNames. In this method, we return the column names that are required for the style to draw the feature properly. For example, if you have a style that colors areas blue when a certain column value is over 100, then you need to be sure you include that column name. This will ensure that the column data is returned to you in the feature when it is ready to draw.
Return Type |
<!– ThinkGeo.MapSuite.PortableCore.HeatStyle –> Go Back
Return Type |
Collection<GeoColor><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.GeoColor} –> |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
