<!– Enumeration –> This enumeration determines how a texture is filled in with a GeoTextureBrush when the area to be filled is larger than the texture.
This will allow you to achieve a number of different effects. We suggest you try them out with your own textures and see which one looks best for your image.
| Name | Summary |
| Tile | The texture is tiled to fill the entire area. |
| Clamp | The texture will not be tiled. |
| TileFlipX | Reverse the texture horizontally and then tile the texture. |
| TileFlipY | Reverse the texture vertically and then tile the texture. |
| TileFlipXY | Reverse the texture horizontally and vertically and then tile the texture. |
